After all the thrill of finally removing the stubborn screws that held the oil baffle plate in place, I discovered that thing cannot be removed!! Seems like there are some rivets directly into the crankcase. I tried prying with a screwdriver, but that plate seems to be easyly broken -before even starting to bend. The reason for wanting to remove it is, as you can see in the picture, that the crankcase is full of sludge and aluminium shavings, and I want to pressure wash it thoroughfully. How -if possible- can that plate be removed?
Raul
