Author Topic: My CB500 Four restoration project  (Read 1800 times)
tomdaenen
« on: August 10, 2009, 01:22:25 AM »
Hi all,
some time ago I bought a nice, old CB500 Four.
Well, certainly old in any case... When I bought it, it did't run. The least I knew whas that the engine hadn't seized (I could get it around using the kickstarter).
It came without vehicle documents, but I got a second frame with documents.
So now I'm finding my way through my very first restoration project  :)
Basically I'm looking at stripping it down, checking/cleaning/repairing the parts and putting them into the second frame. Is there anybody who can give me some advise of what would be a good plan succeed this project?
Thanks and best regards,
Tom
http://gallery.sohc4.net/main.php?g2_itemId=307273
Offline lynchj
  • Life is short ...go for a ride now
Re: My CB500 Four restoration project
« Reply #1 on: August 10, 2009, 06:04:21 AM »
Hi Tom,  welcome to the SOHC site, there is tons of great advise here on all aspects of a restoration. I may not be the best to advise you but I'm about 1/2 way done (optimisticly thinking ha ha) with my 73 500-4 and this is my first motorcycle rebuild.  I started with the motor, mine was siezed, I ended up replacing all of the seals, rings, cam chain, gaskets, lapping in the valves and minor port cleaning. I have yet to see if it will start. Once that was done I started on the frame and I'm taking it one piece at at time. I'm somewhat budget constrained so I can only spend so much each month and I expect that it will take another 6-7 months if I keep up the same pace. Spring 2010 is my goal.
 Depending on your goals and the condition of your parts it could be relatively simple or painfully slow (like my build).
Good luck and I'll try to keep up with your project build.
my CB500 build thread   http://forums.sohc4.net/index.php?topic=54143.0
Other toys: 98 YZ125, 70 MGB, 99 Camaro
