Author Topic: No power, fuse is good  (Read 903 times)
71cb500kid
« on: August 10, 2009, 09:35:46 AM »
Hey there fellow cb's I have had a headlight problem draining the battery. After about 10 minutes so I had unplugged it thus making the bike run forever. So I rewired the wiring up the original place for them to be. Now I have no lights anywhere at any ignition position. Fuse is good at the connectors as well. Wondering if I have crossed wiring at some point. Bike is 38 years old has total molestation in the wiring.. wish I luck thanks guys and girls. Battery has voltage as well
« Last Edit: August 10, 2009, 10:35:22 AM by 71cb500kid »
Offline GammaFlat
Re: No power, fuse is good
« Reply #1 on: August 10, 2009, 11:50:57 AM »
Are you certain the fuse is good?  They can look perfectly good and "disconnect" at the end (where you can't view the innards).
K6
85 Goldwing
Offline Patrick
« Reply #2 on: August 10, 2009, 01:25:45 PM »
If it was my bike, the first thing I would do is undo everything I had done. If the other lights come back then you know it's something in the repair you made. If they don't, pick up a $5 circuit tester light at an auto parts store and trace the wires to find out where you are losing juice. Wiring can be a pain, but it is just tedious, not difficult.
Patrick
1970 CB750 K0
1982 VF750S Sabre
1987 VT1100 Shadow
1979 Yamaha XS11
1969 Yamaha DT1B
etc.
Offline NickC
« Reply #3 on: August 12, 2009, 08:59:27 AM »
I had a pretty similar problem, turned out to be the ignition switch.
