Author Topic: 1.75 oz wt needed to balance rear tire  (Read 915 times)
Offline lowmileage
  • Gotterdone
  • At Montauk Point Circa 1975
« on: August 12, 2009, 08:44:23 AM »
That's what was needed  :P . Sounds like a lot, no  ???.  And I read somewhere it's not necessary to balance your rear tire  :P.  It's a Continential K112 4.00 x 18 and they don't have balance dots on the tire.
ps.  mounted her myself  8)
 ;D
1975 750 K5 Original owner -  11K miles.  On the road 8/09 after 26 years in storage.
2004 Harley Superglide - bought new
1973 Honda CL350 - sold in '75 to buy the "750"
Offline Triffecpa
Re: 1.75 oz wt needed to balance rear tire
« Reply #1 on: August 12, 2009, 09:47:19 AM »
I typically don't balance the rear tires.  That seems like a bit of weight, but if it balances it out, then it shouldn't be a problem.  You might try letting the air out and rotating the tire 180 degrees on the wheel and reinflating and checking the weight required to balance the wheel again.
Tracy
Offline lowmileage
  • Gotterdone
« Reply #2 on: August 12, 2009, 09:54:17 AM »
I was thinking about that but didn't want to ***k up the innertube valve.  Thanks
