Author Topic: 350F Carb question.  (Read 983 times)
Offline XxDarkEuphoriaxX
  • bangle bangle bangle
350F Carb question.
« on: August 12, 2009, 11:29:04 AM »
Hi, what are the (2) breather like tubes coming out of the top of the carbs on the 350F? does nything ever come out of them? do they need to be there etc? how long do they need to be?
thx adam :D
btw the bike is finally running!
1972 CB350F
Offline schneider419
Re: 350F Carb question.
« Reply #1 on: August 12, 2009, 02:10:51 PM »
THEY KEEP A VACUUM FROM FORMING IN THE CARB BOWLS. I CUT MINE DOWN TO ABOUT 5 OR 6 INCHES AND ALL IS GOOD.
« Reply #2 on: August 12, 2009, 03:12:32 PM »
mine are over 12" if not more. ... now my bike acts like it is starved for fuel... I have to keep the fuel going to keep it idling..... it didnt do this after I first got it but I rode it around the yard a few times and now it wont idle and picks up speed reeeeeeeeealy slowly..
HELP  ???
1972 CB350F
Offline Lars
« Reply #3 on: August 13, 2009, 04:15:13 AM »
As Schneider says, the two hoses bring an atmospheric pressure into the carbs, avoiding a vacum to build up as the engine runs. The atmospheric pressure also helps pressing the air/fuel mixture into the jets and into the venturi where you have a low pressure sucking the mixture up.
I would recommend you to do the standard procedure tuning up your bike. That is a valve adjustment job, points gap and timing, cam chain tensioner (if the engine runs) and synchronising the carbs. However, if the bike has not been in regular use for a long time, you have to take them off the bike and clean them properly. To have the complete joy of any vintage MC, this is the only way to go. You can do it yourself, it is not difficult. Use this forum for advice as you go and maybe ask some questions before you take the carbs off. You will need an instrument to synch your carbs, maybe someone on this list around you to give you a hand on that.
These are great bikes - good luck with it!
Some advise to find here: http://www.hondahobby.no/website.aspx?displayid=1736
Lars
...if you got the ability to act...
