Author Topic: how to cb 750 k4  (Read 898 times)
Offline neil10
how to cb 750 k4
« on: August 13, 2009, 04:57:13 AM »
How to fit double piston caliper
 not enough room on inside
Offline lordmoonpie
    • Moonpie
Re: how to cb 750 k4
« Reply #1 on: August 13, 2009, 07:38:14 AM »
If it will fit and it's just slightly too thick, file off the back of the caliper. It sounds drastic but you only need a couple of mm clearance and is a common modification over in the UK for AP calipers onto CB35, 450 and 750 racers. Of course if you go too far you will need a new caliper.  ;D How much of a problem do you have?
It could just be that the caliper you have simply cannot be made to fit...what make/model is it?
1994 Ducati 888 SP5
1951 Ducati 50cc Cucciolo
1981 Yamaha XV750 SE
Offline neil10
« Reply #2 on: August 13, 2009, 02:15:21 PM »
yes I tried fj1200 rear disc way to wide
