Author Topic: VM29's emulsion tube threads are stripped on the carb body  (Read 2308 times)
Offline Turbogrimace
    • Draft Cycle Works
« on: August 13, 2009, 09:27:00 AM »
How the heck am I going to fix this?  Has anyone dealt with this before?  These carbs were built for constant jetting changes and I guess someone went one too many turns at some point and stripped out the threads on the emulsion tube.  I was thinking jb weld as the quick fix, but is there a way to helicoil this?  Has anyone done this before?  Know the thread dimensions?
Any information would be great, thanks fellas.  My 836 is fiending for fuel.
Offline BLUE71TURBO
Re: VM29's emulsion tube threads are stripped on the carb body
« Reply #1 on: August 13, 2009, 01:59:23 PM »
HEY GRIMACE !  I had the same problem on a set of 29 smoothbores, 2 bodies were stripped.  DEVCON is the best stuff in my opinion.  I used a flat tooth pick and smeared a little on the threads and installed the tubes. Then i smeared a little more around the base of the tube. I then let it sit for 24 hours, then installed the carbs, and never had a problem again. I even did jet changes many times as i had them on a 1132 kawasaki that i had over the years. They are still being used now on another bike !!   ;D
    • Draft Cycle Works
« Reply #2 on: August 14, 2009, 05:19:17 AM »
Will the Devcon allow me to take the emulsion tube out at a later time or is it permanent?
Sounds like a good idea so far!
Offline BLUE71TURBO
« Reply #3 on: August 14, 2009, 09:34:17 AM »
PERMANENT !
    • Draft Cycle Works
« Reply #4 on: August 14, 2009, 09:41:39 AM »
NOOOOOOOOOOOOOOOOOOOOOOo hahaha.
Doesnt the emulsion tube thread into the Jet block?  If so, I could take the jet block out plug it and retap it.  That or Sudco still has a PN for it, I might see how much it costs.  Does this sound right?
Offline BLUE71TURBO
« Reply #5 on: August 14, 2009, 10:10:06 AM »
The emulsion tube screws into the aluminum body. Here is an exploded view of the carbs. When you get the picture, left click on the diagram to enlarge it. # 42 needle jet just screws into the body, no other piece is there.  :(
Good luck !   ;D    http://www.pjmotorsports.com/Jets%20Pics/expvm29.gif
    • Draft Cycle Works
« Reply #6 on: August 14, 2009, 11:16:43 AM »
What I'm saying is that the needle jet screws into the Jet block, not the carb body.
Offline BLUE71TURBO
« Reply #7 on: August 14, 2009, 12:47:34 PM »
Hell, it's been so long sense i have seen the insides of a mikuni. I run a SU carb on my turbo. I'll have to take a trip to my friends shop and take a look at a carb to see what yer talking about.   ;D
Also your post state's "emulsion tube threads are stripped on the carb body"  ?
« Last Edit: August 14, 2009, 12:53:04 PM by BLUE71TURBO »
    • Draft Cycle Works
« Reply #8 on: August 14, 2009, 01:16:17 PM »
Yeah, that was waay back in the day when I just got these carbs (yesterday) and thought that the ET was tapped into the carb body.  I should change the title, but it's not really broken, just wrong.
