Author Topic: Need advice on new 630 chain for my 77 750k  (Read 1722 times)
MrHellpop
« on: August 14, 2009, 01:56:10 PM »
Experts, I need your help!
I currently have a super stretched and sketcy 630 chain on my bike, so it's time to replace it! The problem is, I have no idea which chain to buy, and if I should go o-ring or not. I would like to get a decent, safe chain while spending as little money as possible... I don't ride the bike super fast, mostly just cruising backroads and going no faster than 65, so I'm sure I don't want or need the super high performance sportbike type of chain.  All of that said, I know absolutely zero about chains. The only reason I know I have a 630 is because I can actually see that number stamped on the side of the links of my chain ha ha.
So!
What do you experts recommend? I looked in the FAQ but am still very confused on the differences between o-ring and not o-ring, how many links I should have, and even how the hell do I get the old one off and put a new one on! When I look at my old chain, I don't see any clips on either side holding a 'master link' type link together, so I assume that I have a non o-ring chain? I have heard about something called a chain breaker... do I need to buy/rent one of these things to get the old one off?
Yes, basically I am asking for a tutuorial on how to get the old chain off, which new chain to buy, and how to get that new chain off!  ;D
Any info at all is greatly appreciated!
(please don't lecture me on the 'spending as little money as possible' part of my post! I want the best chain I can get for my bike at the best price is all! I know you get what you pay for and all that jazz, and I'm not looking to cheap my way into a horrible sub-par chain, while at the same time I don't need the 'pro' or 'superbike' type chain!  ;D)
Offline HavocTurbo
  • Angry little bastard of an
  • Can you tell?
Re: Need advice on new 630 chain for my 77 750k
« Reply #1 on: August 14, 2009, 02:49:15 PM »
Before you buy.... send me a PM. I'll work with you.
Some questions.
Where do you usually ride? Highway or city?
Ride hard or light?
Stock rear suspension and wheel?
Original sprockets?
What's your gearing? (if you know)
And finally what size tires are you running?
This is my starting point. I'll have more later.
'48 HD Panhead - Exxon Valdez
'78 CB550K - Fokker CB.3
'78 Honda CB750K - Mavrik
09 XL883L - No Name
Offline medic09
« Reply #2 on: August 14, 2009, 03:13:12 PM »
If you don't have a Clymer manual yet, get one.  Also the Honda shop manual, which you can download as a pdf file, I believe.
O-ring is pretty much a modern standard by now.  Some of us still use non O-ring, and that's fine too.  Non O-ring should cost you a little less, but require a little more regular maintenance.
You will need either a chain breaker tool or a grinder to get a link off and open the old chain.  Motion Pro is one of the reputable companies, of many, that sell them.  I don't personally like the little ones suitable for roadside repairs.  I like a heavier tool that will live in my garage.  You'll be changing chains and sprockets regularly over the years with your bike; might as well have a decent set of tools.
BTW, what about your sprockets?  'Common wisdom' is that sprockets either get changed with every chain, or every other chain.  Depends on who you talk to, and who's paying.  :D  But if this is the first time, I would definitely consider sprockets along with the chain.  Simple job.  They bolt straight on as replacements.  Old sprockets will wear a new chain unevenly, and likely cause an earlier need for replacement.
As for the chain, there are plenty of reputable brands out there. I've got D.I.D O-ring on mine, just now.  You'll have to choose what kind of master link you want.  I personally don't like clips; but they've been successfully used for a very long time, including on the racetrack.  Somehow, I never seemed to get them quite right.  A rivet master link is as secure as a regular link on the chain, but you'll need a special tool for that.  Personally, I thought it worth the investment and peace of mind after losing two clip links due to my ineptitude.  There is also a screw on link, but I've not heard them ever mentioned on this forum.
To get the old chain off, you'll need to loosen the chain with the adjusters at your back axle.  Remove one link, and the chain comes off.  NOW, some folks attach an open end of the new chain to the old one, and use the old one to thread the new chain onto the front sprocket.  Me, I like to work with everything open.  Besides, you may want to replace that sprocket now anyway.  So, link off and chain off.  Front sprocket cover off.  Note exactly how the sprocket is mounted for your model.  The 77 and 78 K bikes are straightforward.  Now's a good time to take some rags and Simple Green and clean up that sprocket area.  I'll bet it is full of 30 years worth of gunk.
I'm typing off the top of my head, and don't recall how many links you need in your chain.  (Same as mine...)  If it is a  few links too long, you can easily remove a few.  If it is too short, well...that's a little harder, though fixable.  But more than one master link isn't really good.
Mount the chain around your two new sprockets.  (Again, that's just my advice.)  Pull it around to where you can work with it.  Place the master link, press on the other half, use the rivet tool (assuming you got the rivet link) to secure it, and you're good to go for thousands of miles of riding pleasure.  The 77 K is a great bike.
That's your primer.  Use the search function to find the previous threads about chains. Some good info already covered, and worth your reading.
Also:
http://www.motorcycle.com/products/all-about-chains-3524.html
Good luck!  More knowledgeable folks will speak up here soon.
Mordechai
'78 CB750K
'07 aprilia Caponord
Santa Fe, NM
