Author Topic: need help removing carbs on a 73 cb350f  (Read 966 times)
Offline jamesv220820
« on: August 21, 2009, 06:55:23 PM »
ok well i want to take all 4 carbs off to clean them but i dont know how and the shop manual doesnt seem to be helping
i have the rear collars and the front colors loosened up and the back chamber will wiggle but now i don't know what to do
i looked at probably a dozen forums already but none have helped maybe because they were for different bikes
any help would be great
-james
There is nothing to fear but fear itself . . . and trying to restore a cb350f
Offline jeepster
Re: need help removing carbs on a 73 cb350f
« Reply #1 on: August 21, 2009, 07:03:38 PM »
Do you have any ratcheting tie downs? If you do, use it to pull back the airbox. You might also be able to keep them pulled back with some rope.
Another way it to have someone pull back the airbox while you pull out the carbs. Wriggle them a bit when you pull out. Sometimes using the handle of a clawhammer (rubber not wood natch) like a fulcrum can help ease them out. If none of this works, heat up the boots with a hair dryer.
Oh yeah, you should also take the tightening bands off the airbox boots before you try to pull the carbs out. Very easy to mangle them trying to get the carbs out. (Ask me how I know.  ;))
« Last Edit: August 21, 2009, 07:05:39 PM by jeepster »
"An ounce of prevention is worth more if you break it up into nickel bags."
Offline tomkimberly
« Reply #2 on: August 21, 2009, 10:34:36 PM »
A picture is worth a 1000 words....
Tom
Offline CrashBar
« Reply #3 on: August 22, 2009, 05:10:00 AM »
I loosened all the bolts on the metal airbox as well, and pushed it back some, and then took the plastic piece right out.
....to trade in these wings on some wheels...
2017.5 BMW R1200GS
1973 CB350F
1978 CB550K
1973 TR5T
Offline fmctm1sw
« Reply #4 on: August 22, 2009, 06:22:18 AM »
That's what I do.  You have to pull up on it first to clear the stud under the battery though..
Quote from: 754
Quote from: inkscars
This is not a pod thread
1973 CB350F
1973 CB350G
1975 CB550K
1983 GL650I
1994 Honda TRX300
1999 Honda TRX250
« Reply #5 on: August 23, 2009, 06:56:45 PM »
hmm well i'm closer then i was but when you talk about heating the boots do you mean the ones towards the front of the bike bacause i got the rear ones going to the air box off pretty easily
-thanks
james
Offline bender01
« Reply #6 on: August 23, 2009, 09:56:29 PM »
It takes strength to get them off!!! Twist, roll ,rock, side to side,push a little to the right to get some more of the left.!! Etc. Do be careful putting them on that way. You will easily knock it off the centerstand!  ::)  Ive only had mine off @ .....10 times in 2 years and not once this summer. So when you get them off search all you can here and save yourself the hassle.  BTW ive nver had a problem getting them off, but putting them on I use a space heater to warm the whole area up. Hope this helps.
75 550 K1
74 750 K4
1968 450 K1 Super Sport
74 750k 836 project
Good luck!
Two Tired Quote !
