Author Topic: Another CB550F mpg question?  (Read 5853 times)
Offline Pinhead
  • 1979 CB652-ST
Re: Another CB550F mpg question?
« Reply #25 on: August 29, 2009, 10:54:15 PM »
Do you mean the cylinder walls having the oil washed off them under an extremely rich condition?
Yeah, stuff such as low compression due to bad rings/washed walls, semi-seized bearings, low oil level, drive chain worn out and/or too tight, preignition/detonation due to carbon build-up, etc, etc, etc.
Doug
GM HEI Ignition Conversion
Quote from: TwoTired
:D
Offline crazypj
  • I'm brill, me
« Reply #26 on: August 30, 2009, 11:33:59 AM »
26~43mpg on mine when it was stock, depending how I rode it, (usually closer to lower number  ;D)
 With 591 kit, cam, exhaust and K&N filters, consistent 41mpg, 54mpg if I took it easy
being in too high a gear at lowish rpm when accelerating wastes a bunch of fuel
Didn't you change the carb jetting, sprocket gearing, too?
 Only changed rear sprocket 1 tooth smaller and jetting was quite a bit richer. Spent a lot of time getting mid range right though
Offline brianzenk
  • I love Hondas
    • Crazy ART stuff - BEWARE
« Reply #27 on: August 30, 2009, 02:02:14 PM »
I'm riding a Honda cb550 1976
It is getting 39 MPG
Its stock with lots TLC
'Oh #$%*!' is usually the moment when your plan parts ways with reality !
