Author Topic: Yellow paint on bolts from factory  (Read 2958 times)
Offline mafd2
« on: August 28, 2009, 05:32:32 PM »
Anyone know the reason Honda put yellow paint on bolts?  I was told it was for warranty purposes to tell if the were removed or monkyed with that would void a warranty.  Does anyone or the old timers know if this was the reason or was it something else??
Offline razor02097
  • Not a fool, just an
  • Yes its a Honda You got an F'in problem with that?
Re: Yellow paint on bolts from factory
« Reply #1 on: August 28, 2009, 05:50:21 PM »
I think it indicates an inspection point.  Verifying that the bolt was checked and such.
Project Rina
That is an inconceivably egregious transgression against my rudimentary concordance of socially shunned individuals.
« Reply #2 on: August 28, 2009, 07:37:46 PM »
That is called a witness mark. It serves two purposes. First is signifies that the bolt was torqued. Second it will allow you to see if the bolt has turned due to vibration.
Offline mafd2
« Reply #3 on: August 28, 2009, 07:50:12 PM »
OK that seems to reason. Thanks
Offline spitfire
« Reply #4 on: August 29, 2009, 04:19:29 AM »
Plus it also lets the dealer know what you had been fiddling with !
I use paint spots as an easy way to let myself know that I have torqued something down as my memory is not perfect.
Cheers
Den
Wirral UK
1976 CB750F1 bought new in 76
1977 CB750F2: Restoration started
1964 BSA A65R: Waiting restoration
My gallery is here: http://www.sohc4.us/gallery/v/members/personal/spitfire/?g2_navId=x5a30f7b6
Offline Bill/BentON Racing
    • BentON Racing
« Reply #5 on: August 29, 2009, 06:02:16 AM »
Bobby R nailed it,main reason from Honda was to indicate it was torqued.Bill
BentON Racing Website
BentON Racing Facebook
Offline Raul CB750K1
« Reply #6 on: August 29, 2009, 03:35:53 PM »
Cheers
Den
If your memory is not perfect, are you positive you paint every single bolt after torqueing it down?
My method is different: if I put a bolt or nut in, I always torque it down correctly -in case of a cover, I torque them down alternatively, but all of them at the same time. That way I always know that every bolt that is in, it has been torqued.
Only use torque wrench on head bolts/nuts and filter bolt. The rest are torqued by "feel".
« Reply #7 on: August 29, 2009, 04:38:31 PM »
In an industrial setting the technique is to torque a bolt and mark it with a paint pen. This allows the quality inspectors to do a quick inspection.
Offline TIM TINGEY, age 55
  • Service manager Matts Vintage Motorcycles
  • 916 208 0935
« Reply #8 on: August 29, 2009, 05:47:38 PM »
The yellow paint is to signify that a critical area related bolt or nut has been torqued. Its a  quality control tool. Typically you see it at swingarm, steering head, axle, and brake points.
