SOHC/4 Owners Club Forums
Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News:
The
SOHC/4 World Tour
is in under way.
Home
Help
Login
Register
Donate
Tech Forums
SOHC/4 Bikes
Topic:
Front Brake Pad Drag
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: Front Brake Pad Drag (Read 967 times)
quidger
Enthusiast
on:
August 30, 2009, 11:24:23 AM »
The front brake pads on my '78 CB550 are dragging slightly. Just enough that it is difficult for me to pull the bike backwards and the rotor becomes extremely hot after a trip around the block.
Can I make an adjustment to free the pads up a bit without having to totally bleed the system.
Thanks.
Logged
TwoTired
Really Old Timer ...
Re: Front Brake Pad Drag
Reply #1 on:
August 30, 2009, 12:00:52 PM »
Probably not.
There is a front caliper rebuild walk though in the FAQ.
But, if the master isn't reliving the system pressure, then make sure the tiny hole at the bottom to the fluid reservior is clear.
Logged
Zaipai
I am getting closer to being an
Old Timer
Reply #2 on:
August 30, 2009, 12:07:14 PM »
Also make sure the adjustment arm is on correctly. Mine was not once I fixed it things were back to normal. I had the order of install wrong.
Logged
Its my Avatar..
75 CB550F
Bubba0374
Full Member
Am I right? or Am I right?
Reply #3 on:
September 01, 2009, 03:06:12 PM »
had the same problem on my 500, after i cleaned the piston out and cleared all the lines it worked fine.
Logged
73 CB500, 75 CB750, 74 XL250, 83 CR250, 78 Nova Rally, 54 Willys Cj3b
Print
Pages: [
1
Go Up
« previous
next »
Tech Forums
SOHC/4 Bikes
Topic:
