Author Topic: Spoke lacing. DIY?  (Read 2445 times)
2tall
Spoke lacing. DIY?
« on: September 14, 2009, 06:43:22 AM »
I'm going to get some new spokes for my bike this winter, and I am a bit intimidated at the prospect of lacing them myself. What do you guys think? Can this be done by an amateur? I have a dial indicator and lots of patience/time, but zero lacing experience. How much time to DIY, or how much $ to have it done at a shop?
Opinions please...
Paul
Offline Bob Wessner
  • "Carbs Suck!"
Re: Spoke lacing. DIY?
« Reply #1 on: September 14, 2009, 06:51:59 AM »
Have a look at this write-up, maybe it will help you decide. It's very well done.
http://forums.sohc4.net/index.php?topic=368.msg205745#msg205745
« Reply #2 on: September 14, 2009, 07:53:27 AM »
Its a good write up only addition i would make is only lace up the 20 that go through the holes outside to inside first and true on those first, its a lot easier dealing with 1/2 the number!!! then fit the other 20 and tension the same.
Also a DTI is way more acccurate than you need and will drive you crazy trying to dial out the "Kick" where the rim is welded (Cant be done by the way!!)
Offline Trav-i
  • Has finally become an
« Reply #3 on: September 14, 2009, 10:30:48 AM »
That is the write up I used when I did my wheels (thank you Bob).  I did them both in about a half an hour, having never done something like this before I think I did pretty good.
Don't let it intimidate you it's really easy, trust me. ;)
Forum member #9962
1992 GL1500 Interstate
Offline 033A2
« Reply #4 on: September 14, 2009, 04:08:18 PM »
I laced mine having no experience and after a few misteps, got it with no problem once I figured out the pattern.  I used the instructions noted above as well and after figuring out the front, the rear was super easy.  I didnt true mine though. Once the spokes were laced and snugged up I brought the rims and tires to a shop to true them and mount the tires.  Go for it, you got nothing to lose.
Offline Popwood
« Reply #5 on: September 14, 2009, 05:56:22 PM »
It's completely doable. Takes a few hours the first and second time. Takes a bit of patience and a methodical approach. Using the instructions helps a lot. Changing tires not so bad either. Worst case, you ruin a tube or two trying. Relatively cheap lessons. And yes, you can use a dial indicator. The last rim we did was on my 750 and my recollection is we got it within 15 thousandths. It is helpful to have a wheel balancing stand, available at Harbor Freight for around $30, maybe a bit more. If you got the time, take on the project. The personal rewards (and $$ saved) are priceless.
Current Rides:
1975 cb550K
1975 cb750K
1967 Bridgestone 350GTR
Past Rides:
1988 400 Hawk
195? Schwinn Whizzer
Offline Bill/BentON Racing
    • BentON Racing
« Reply #6 on: September 14, 2009, 06:05:35 PM »
Lacing relatively easy,harder part is truing it,If you put 20 inside spokes in and tighten too much,will be harder or not possible to put in ousides without loosening the insides,so put them all in and then true using the insides first.Just ran into it again lacing up Calendar Girls f/wheel,Buchanans,2.15x18 gold anodized,had too loosen the insides so I could install outsides properly.Bill
BentON Racing Website
BentON Racing Facebook
Offline Bob Wessner
  • "Carbs Suck!"
« Reply #7 on: September 14, 2009, 07:24:05 PM »
Don't thank me, thank Dan Jones.  ;)
Offline tlbranth
« Reply #8 on: September 14, 2009, 07:39:04 PM »
Not that difficult and very satisfying. Give it a go.
Don't own a Vanagon
Don't work at Boeing
Life is good
1970 CB750 K0
1975 GL1000
1999 GL1500
Terry
Offline Chris Elliott
« Reply #9 on: September 14, 2009, 07:40:39 PM »
where would you recommend getting new spokes from?
    • BentON Racing
« Reply #10 on: September 14, 2009, 08:01:55 PM »
Buchanans,626-969-4655,www.buchananspokes.com,Bill
Offline tlbranth
« Reply #11 on: September 14, 2009, 08:02:31 PM »
I got one set from Sudco and another from Parts'n'more. Both seemed very good quality but Parts'n'more were a site less money.
Don't own a Vanagon
Life is good
1970 CB750 K0
1975 GL1000
1999 GL1500
Terry
Offline 033A2
« Reply #12 on: September 15, 2009, 04:15:37 AM »
Got mine from David Silver Spares.  Wanted the Buchanan's but the price was a bit much.  Very happy with the the ones from DSS.
Offline Trav-i
« Reply #13 on: September 15, 2009, 09:10:46 AM »
Good point Bob.
Thanks Jonsey!! ;)
Forum member #9962
