Author Topic: New exhaust possible new problems  (Read 1423 times)
vintage guy
« on: August 30, 2009, 06:03:16 PM »
I have an all stock 1978 CB550K runs perfect with no problems I recently installed a new Mac 4 into 1 exhaust system. Once installed the bike fired right up with no idle issues I have put about 150 miles on the bike and the air temperature has been roughly 65 degrees. I think I might have a slight lean carb issue now and is there way to richen the system without pulling the carbs off. The air box is all stock. Any suggestion or comments would be greatly appreciated I don't want to ruin the bikes engine. any idea what the engine temp should be or the temp of the header
« Last Edit: August 30, 2009, 06:17:03 PM by vintage guy »
Offline 1timduke
  • '75 CB550
Re: New exhaust possible new problems
« Reply #1 on: August 30, 2009, 06:26:13 PM »
Take a look at the plugs, are they whitish?
What makes you think that it's running lean?
-Tim
The only thing I miss about the South is Waffle House!
vintage guy
« Reply #2 on: August 30, 2009, 06:30:22 PM »
I don't know really it seems to have power and take off like a bat out of hell its the sounds it makes when taking off quick and seem to have a very slight hesitation. Is there anyway to adjust the carbs with out tearing the carbs down.
             -- CHRIS --
« Last Edit: August 30, 2009, 06:44:55 PM by vintage guy »
« Reply #3 on: August 30, 2009, 07:23:49 PM »
You can adjust the mixture at idle using the front screw. This is only the idle mixture.
vintage guy
« Reply #4 on: August 30, 2009, 07:36:46 PM »
Is that the screw on the bottom the carbs facing the front of the bike what are the stock settings
Offline lone*X
« Reply #5 on: August 30, 2009, 07:51:41 PM »
Welcome to the board Chris, you will find it very informative.  If you aren't sure yet what you are doing just take your time and do your home work before starting to mess with the carbs.  The 550 is a rugged design and is somewhat forgiving.  If it is running well and idles fairly good you probably are not going to hurt anything.  I ran a Mac 4into1 for years on my 75 550K with the stock carb setup and never had any issues.
Now first things first.  If you haven't done so yet you need to do a complete tune up, plugs, points, timing, cam chain tension, valve adjustment, and air filter.  This will eliminate a lot of other variables and get things right with the engine.  Only then should you start worrying about the carbs.  Next go to the FAQ forum and search for "plug chop" or "reading the plugs"  and then perform the plug chop as described.  The color of the plugs will tell you if you are running lean, just right, or rich.  There are some color charts/pictures there I believe that will guide you. Only after you know how your carbs are actually running should you think of tearing into the carbs.  If that is still necessary then again go to the Carb FAQ or search on rebuilding the carbs.  Been discussed many times.
Good Luck.
Lone*X  ( Don )
75 CB550K1
VTX1800C for two up cruisin.
« Reply #6 on: August 30, 2009, 07:54:56 PM »
All things being perfect you close them and go 1 1/2 turns out. After 30 years you kind of have to listen. Now when you do that try to put a wet rag against the jugs, since you will burn yourself. Not much room there.
Offline bucky katt
  • i am a pastafarian!
    • facebook
« Reply #7 on: August 30, 2009, 08:01:49 PM »
pull the plugs, that will show whether it's running lean or not
Mark Twain - Notebook, 1894
vintage guy
« Reply #8 on: August 30, 2009, 08:02:11 PM »
Thanks lone*x when i bought the bike in March 12, 2009 i bought a new air filter, ngk plugs (standard heat range), points were only six months old at the time. Did you have to go to larger jets when you ran the 4into1 exhaust
« Reply #9 on: August 30, 2009, 08:06:13 PM »
I am running 120s with stock exhaust. I am rich bit I don;t really care. I change the plugs every year. I rin a lot of highway so they don;t get too dirty.
vintage guy
« Reply #10 on: August 30, 2009, 08:06:25 PM »
I'll pull the plugs tomorrow when I get out ofwork I have an shop/repair manuel with pics of normal and non-normal plug wear, but when I put new ngk plugs in the bike in march the plugs were a light brownish white withno black specks or burn marks
vintage guy
« Reply #11 on: August 30, 2009, 08:12:11 PM »
Yeah a far as I am aware the bike still has the number 100 main jets in it
vintage guy
« Reply #12 on: August 30, 2009, 08:17:43 PM »
Wednesday I am going to be wrapping my exhaust header do I need to be aware of anything besides it looks good  ;D
