Author Topic: smallest battery to retain starter?  (Read 3598 times)
Offline verboten1
  • Der König
« on: August 30, 2009, 06:08:41 PM »
What would be the smallest capacity AGM battery I could get away with and still retain the ability to use my starter sometimes.
the bike kicks over pretty easy, but some days I don't feel like being "cool" lol
1975 CB550F
1982 XV920
2000 KLR65085
Offline bucky katt
  • i am a pastafarian!
    • facebook
Re: smallest battery to retain starter?
« Reply #1 on: August 31, 2009, 02:18:29 AM »
i wouldnt even try using anything but the stock size battery. the charging system and batteries on these bikes are just barely enough. i actually modified the battery box in my k4 750 to take a larger battery.
Mark Twain - Notebook, 1894
Offline lordmoonpie
    • Moonpie
« Reply #2 on: August 31, 2009, 03:07:27 AM »
Didn't Rob (voxonda) have a really neat battery solution he'd come across recently?
1994 Ducati 888 SP5
1951 Ducati 50cc Cucciolo
1981 Yamaha XV750 SE
Offline nippon
    • Classic Cycle City
« Reply #3 on: August 31, 2009, 05:33:13 AM »
Hawker EnerSYS SBS8,...one of the strongest, smallest, best and horrible expensive batteries.
http://www.gotbatteries.com/index.php?mfg=Hawker&make=Enersys&model=SBS8&m=search&fID=SL200&sID=36L200S1
Dimensions:  5.40"L x 3.40"W x 4.00"H
Weight: 5.9 Pound(s)
I use one in my 750 K1,...I had to put an 3" high polystyrene under the battery in order to reach the cables.
I never thought about the battery the last three years.
And I paid half of the current price.
nippon
« Last Edit: August 31, 2009, 05:39:18 AM by nippon »
Offline voxonda
« Reply #4 on: August 31, 2009, 05:47:14 AM »
Thanks LMP,
For this the B4600, like the Hawker expensive, but very light and small, <900 grams and 114 x 62 x 81 mm. I use the even smaller B2300 but have no starter. These batteries are used in both World Supersport and Superbike championships by several teams.
Rob
Offline lordmoonpie
    • Moonpie
« Reply #5 on: August 31, 2009, 07:47:33 AM »
Rob,
So without your starter is this battery enough to run the bike up and say do a couple of races without going flat? The reason I ask is that with my startin gproblems I think I might go back to battery power and if so, I want as small a battery as possible to hide it from view...where do these batteries come from?
1994 Ducati 888 SP5
Offline Pltfn
« Reply #6 on: August 31, 2009, 07:58:53 AM »
If anyone is interested in trying a smaller battery without incuring much expense here is the one I plan to use shortly.  It may not work with a starter but I figured I would give it a shot.  Hell, for this price I can fit two in my BCR Battery Box and still come in way under the cost of the R1 battery he recomended.
http://www.apexbattery.com/sonnenschein-cr125-battery-sealed-lead-acid-batteries-sonnenschein-batteries.html
-Kelly
Offline voxonda
« Reply #7 on: August 31, 2009, 08:40:13 AM »
Rob,
Hey LMP,
Have ridden 2x 20 min sessions with it so far. No problemo. These batteries can be fully charged in 15 min(!)
I am dealer of these batteries, so you can buy directly from me if you want.
Batteries are Dutch and used by Ten Kate Racing and others.
Rob
Offline Inigo Montoya
« Reply #8 on: August 31, 2009, 08:49:01 AM »
Well unless a person has starting issues, a smaller battery should not be a problem. The starter does not drain 14 amps in 2 seconds. I doubt it uses 7 amps in 2 seconds either. I will try a rebel battery sometime and see what happens. It is MUCH smaller and spins an electric starter.
Offline lordmoonpie
    • Moonpie
« Reply #9 on: August 31, 2009, 10:01:27 AM »
Hey LMP,
Rob
Thanks Rob -  as soon as I get the CR going on battery power I'll let you know if I decide to go down that route and we can talk some more!
1994 Ducati 888 SP5
« Reply #10 on: August 31, 2009, 10:46:30 AM »
FYI, the starter draw varies up to 120 Amps.  It does this as long as the solenoid engaged and power is available.
The stock battery will provide this for about 2-3 minutes depending on the motor's resistance to turning over.
Lot's of variables in this calculation; battery state, oil viscosity, Compression ratio, engine wear, and temperature of engine and battery, etc.
There is more to batteries than just AH rating.  Starting batteries usually have a CCA (cold cranking amps), which gives you an idea how long it will deliver power and maintain its voltage high enough to spark the ignition.
If the battery doesn't have a CCA rating, it is not intended for that purpose and there are no guarantees when putting it in a starter motor functional role.  You can then find one that works (for a while) by trial and error.
Using a smaller than required battery in such a role, shortens its service life, relational to its depth of discharge and frequency of discharge cycles.  So, you might wind up with a smaller battery that you replace twice (or three times) as often, depending on the abuse the battery receives.
« Reply #11 on: August 31, 2009, 12:28:50 PM »
Well there is no real test for life expectancy though. You could take 2 identical batteries and the life can be different. Regardless, I have been using the 5 year old battery from my rebel all day now with multiple starts. It is a 7 amp battery. My system is stock using a halogen bulb. Voltage after each run has been good and I have used the electric each time starting.
Of course this does not test overall life of a battery but then there really is not perfect test for that anyways but it does clear that in mild traffic, if the system is working right, a smaller battery can be used with the starter. Now this IS on a 77 750 so the results on the earlier 750 may not be the same.
Offline ken736cc
  • When the cops pull me over, I usually let them off with just a warning.
« Reply #12 on: August 31, 2009, 01:17:51 PM »
Hi, Ken from Orient Express here.
We can now supply Speedcell Batteries. These are working very well in a variety of bikes.  Not cheap, but proven technology.
http://www.orientexpress.com/advanced_search_result.php?keywords=speedcell&osCsid=3febfdc1e1903f2b2a63c304cc093810&search_in_description=1&x=2&y=6
K0 sandcast(in process of restoration), K0 diecast, K0 cafe racer
BMW R69S daily rider, 71SL350, 71 SL100, 63 SS50
« Reply #13 on: September 01, 2009, 12:47:44 PM »
Day 2 has revealed no issues yet with a smaller battery. keep in mind this battery is 5 years old.
Offline motocyconomad
« Reply #14 on: September 01, 2009, 01:53:05 PM »
that looks like one serious battery
Offline Really?
« Reply #15 on: September 01, 2009, 02:06:36 PM »
It is tiny too.  $160 though.
The Wife's Bike - 750K5
The Kid's Bike - 750K3
Offline bistromath
« Reply #16 on: September 01, 2009, 04:32:04 PM »
Oh those are awesome. Lithium ferrous cells with a built-in charger to supplement the regulator on your bike. A123 cells -- that's the company that does the battery systems for lots of electric cars. I have a friend on the East Coast doing engineering for them.
'75 CB550F
Offline bistromath
« Reply #17 on: September 01, 2009, 06:43:08 PM »
Hey, I was wrong. They're just bare LFP cells from A123. Make your own for $80 or so. Try 3 in series x 3 in parallel for a 9 cell pack, gives a 12V 9Ah pack that weighs in at 3lbs. Usually they cost around $8/cell on eBay. You could do 3 series x 2 parallel for a 6Ah pack that weighs a kilo.
'75 CB550F
Offline HawaiiMike
    • Hawaii realtor
« Reply #18 on: November 26, 2009, 04:20:53 PM »
Is there anything new in the search for small batteries?   I'll need a new one soon and would like an AGM.  As long as it fits in the battery box and doesn't cost more than a used bike I'm interested.
Happy Thanksgiving!
« Reply #19 on: November 26, 2009, 08:28:50 PM »
I used to sell a lot of what we called small square batteries, I think the number is 12N 5.5A or similar.
 A popular choice in choppers and HDs..
 Anyway, they fit in 750s, you will have to shim up with a 2x4 and shim front to back.
 Like the OP says, he does not want to use e-start all the time..
 Well I have run them with stock motors, planning to kickstart all the time, but found in warm weather, with bike warmed up, it will actually e-start quite easily.... they are like 30 -40 bux..
 Unlike the pig I am riding now that wont kickstart, unless I turn the lights off, it charges when I rev it up , but is not holding much in the  stock size battery.. which was new this summer... ::)
Offline wannabridin
  • Patience made me a
  • -Garrett
« Reply #20 on: November 26, 2009, 10:10:20 PM »
go to a local interstate betteries.  i went there with the dimensions i'd like and told the guy there i wanted the most powerful AGM they had.  about $50 later, i had on with more than enough CCA's for my needs.  i'll look when i get home next and see what the model number is.  but it's quite a nice unit.  i just need to put it in the bike now, haha
