2nd clip position from the bottom is stock from what I've read. Also, setting the clip lower will raise the needle allowing more fuel to pass, thus more rich. A little advice... If you do all this work cleaning your carbs and dont clean the tank, you're just asking to go back in and do it all over again. Don't ask me how I know. Good luck with the build, looking forward to seeing your progress.
