Author Topic: What's with the chain length?  (Read 684 times)
Offline mycb750k6
  • "res ipsa loquitur"
  • Rocketman
    • photobucket albums
« on: March 06, 2010, 05:51:29 PM »
I don't know what I did with the old chain but bought a new 100 link 530 for my K1 with 48 and don't know what's up front. I was assuming 17. Anyway it's not long enough. I think I need a 102 and where to get those? Any why isn't it long enough the first place? I got it on but there's no adjustment forward - none.
Offline dusterdude
Re: What's with the chain length?
« Reply #1 on: March 06, 2010, 06:04:06 PM »
i know motogrid says 100,but i think ive seen 104 listed by aftermarket sources
mark
1972 k1 750
1949 fl panhead
1 1/2 gl1100 goldwings
1998 cbr600 f3
« Reply #2 on: March 06, 2010, 06:14:25 PM »
Stock sprockets on a K1 are 18/48. Chain charts do show 100l as correct, but it would be tight as you've noticed. Too tight to run?
It'll likely set in quickly and give a little.
Longer chains should be available from all aftermarket sources.
Offline mycb750k6
  • Rocketman
« Reply #3 on: March 06, 2010, 06:25:57 PM »
No it's not too short to run but almost. As Hondaman pointed out in his book, a Little extra wheelbase is goodness however. Somehow I was under the impression from the book that the early 71s were 17/48. Which would have more top end speed, the 18? I could have mis-read it.
« Reply #4 on: March 06, 2010, 07:28:12 PM »
I would agree on the wheelbase, and using a longer chain achieves that. We did that on our roadracers.  A 17 t front with a 102 link chain put the wheel back for high speed stability.
An 18t gives the higher top end, assuming you have the horsepower to pull it. Otherwise it lowers the rpm at cruising ranges, the bigger reason for using it. I prefer 17/48 overall.
Reference HM page number. I've read that section and didn't see that (17 std on K1s). Easy to miss tho with the volume of text there.
