The readings that you will get from a compression test will be affected by many things other than the actual compression of the the cylinder being tested. Your procedure for testing is one of them. The internal volume of the compression tester is another (this one can make a huge difference in a small engine; read TwoTired's posting in the "tricks and tips" section). Proper testing procedure typically involves: fully charged battery and properly functioning starter, all 4 plugs removed, throttle held wide open or carbs removed, good seal to the cylinder head. The most important thing is to be consistent in the testing of all 4 cylinders. In your results, you are looking for consistent numbers between your cylinders, more than comparing absolute values to those in the books.
