well the retainer is off, just have to get the bearings out, tried heating the hub up, but no joy, bearings must have moved slightly out has inner spacer is loose,
think i have hit wrong part of bearing though as the cover of the bearing came shooting off and a part of the metal strip which i think holds the bearings has started to unravel.
bearings are in real tight, any more suggestions, or heat it up further and keep whacking , should i keep trying and do what ever it takes to get this bearing out , whether it comes out in bits or as a whole unit
