Author Topic: rear retainer questions  (Read 5986 times)
Offline MIKE550/4
« on: September 10, 2009, 12:04:25 AM »
550 k3 78 uk bike/member
hi all
questions on rear wheel , firstly... front wheel had to drill the stakes out on retainer, is this the same on rear ? i e are these staked ( if so how big to drill and how deep to go and exactly where are they staked is it in the 4 holes where you put your tool to remove )
pic attatched if you look closely you can see punch marks in the 4 holes ?
also is this a right hand thread ie turn right to unscrew
lastly brake linings look new but on drum very light surface rust has started to appear can i remove this rust myself or would it need any professional work done to it
Offline bistromath
Re: rear retainer questions
« Reply #1 on: September 10, 2009, 12:18:38 AM »
You can see the staking right there. Just drill slightly wider than the staking to remove it.
If you remove the gunk on the retainer you will see an arrow indicating the direction to turn to unscrew it. It is a right-hand thread, which means turn it LEFT to unscrew.
Don't worry about very light rust. It will come off with normal use.
'75 CB550F
Offline MIKE550/4
« Reply #2 on: September 10, 2009, 12:37:13 AM »
heard different ideas on thread on this bike,  k3
the arrow points to the left or anti clock wise... so left to unscrew ?
thanks for reply
mike
Offline MIKE550/4
« Reply #3 on: September 10, 2009, 01:20:20 PM »
will drill at week end, and have a go . stakes i take it then are in the 4 holes for the tool, they dont look very deep though
Offline IndyFour
« Reply #4 on: September 10, 2009, 01:33:21 PM »
thanks for reply
mike
I just did the rear bearing on my 74 550K a few weeks ago.  The arrow points in the direction of the threads.....so go opposite the arrow to loosen.  I also had to drill out the stakes.  The Clymer manual suggested a certain size bit and I just used what it said...can't remember what it was at the moment  I tried to make a spanner of my own to unscrew the retainer, but as it turned out a large screwdriver used to tap in each hole in the the loosening direction worked best.
Be sure to use some thread locking compound on the retainer when you put it back together.
Good luck!
« Last Edit: September 10, 2009, 01:36:07 PM by IndyFour »
1974 CB550K
2000 VFR800FIY
__________________
Indianapolis, Indiana
Offline MIKE550/4
« Reply #5 on: September 10, 2009, 01:53:21 PM »
cheers for reply  ;)
had 2 replies with conflicting answers ( if i have read this right )
can someone verify if the retainer has an arrow pointing anti clockwise which way do i turn retainer to loosen
clockwise or anti clockwise
indyfour thinks clockwise ...  The arrow points in the direction of the threads.....so go opposite the arrow to loosen
bistromouth thinks anti clockwise
really dont want to knacker this retainer up as they are hens teeth in uk
Offline IndyFour
« Reply #6 on: September 10, 2009, 02:37:14 PM »
Mike,
If I recall correctly, mine was left-hand threaded (arrow pointing counter-clockwise)....meaning you turn Right to loosen.
Just looked in the Honda shop manual to confirm, and it says the same thing.
1974 CB550K
2000 VFR800FIY
__________________
Offline bistromath
« Reply #7 on: September 10, 2009, 09:23:40 PM »
Listen to IndyFour, it's been two years since I've done it.  ::)
'75 CB550F
Offline Gorms
  • Barkeep! Give me a beer and a
« Reply #8 on: September 10, 2009, 09:30:57 PM »
WAIT WAIT WAIT!   Turn that thing clockwise to loosen it.  I'm positive.
Offline MIKE550/4
« Reply #9 on: September 10, 2009, 11:03:45 PM »
cheers all, i think there were a few with different threads but looks like mine is turn right to loosen
Offline MIKE550/4
« Reply #10 on: September 12, 2009, 11:55:10 AM »
blimey  ??? this is a bit tight any tips for getting this retainer out
Offline IndyFour
« Reply #11 on: September 12, 2009, 01:08:08 PM »
Probably the best way to get it off is by using the specialized tool, but I just ended up using a large flat-headed screwdriver and tapping at each hole in the direction to loosen.  You drilled out the stakes, right?
I've seen some people make their own "wrench" by taking a metal bar and welding two catch points on the flat part....so you can grab both ends and turn that sucker.
Keep at it....it'll come off!  Go drink a beer, maybe that will give you more strength!  ;D
1974 CB550K
2000 VFR800FIY
__________________
Offline Gorms
« Reply #12 on: September 12, 2009, 05:38:12 PM »
I tried a drift and a large hammer but no go.  Ended up taking it to a shop who put a lot of heat on it and banged it off.  Make sure you drill out all of each stake.  I ruined a few threads and it was a PITA to dress them again.
Offline MIKE550/4
« Reply #13 on: September 13, 2009, 02:12:38 AM »
yeah drilled out the stakes, might try a bit of heat on the hub ,
the front one was a pain had to chop out retainer in the end ( soft aluminium) but this one steel so will have to keep trying
think more than 1 beer though to get this sucker off   :D
« Last Edit: September 13, 2009, 12:19:52 PM by MIKE550/4 »
Offline MIKE550/4
« Reply #14 on: September 15, 2009, 09:14:22 AM »
well the retainer is off, just have to get the bearings out, tried heating the hub up, but no joy, bearings must have moved slightly out has inner spacer is loose,
think i have hit wrong part of bearing though as the cover of the bearing came shooting off and a part of the metal strip which i think holds the bearings has started to unravel.
bearings are in real tight, any more suggestions, or heat it up further and keep whacking , should i keep trying and do what ever it takes to get this bearing out , whether it comes out in bits or as a whole unit
Offline MIKE550/4
« Reply #15 on: September 15, 2009, 01:53:27 PM »
by the way definately right to unscrew, had to use lots of heat in the end to undo it though
any tips to get bearings out guys ?
« Reply #16 on: September 15, 2009, 02:10:55 PM »
Yes, get a piece of pipe and a fairly heavy hammer. Heat the hub till it is hot to the touch and drive the bearing out. i did it cold and took me 12 whacks. With heat it took three.
Offline MIKE550/4
« Reply #17 on: September 16, 2009, 12:21:29 AM »
its getting that first bearing out thats causing me the issue
bearings have started to come loose of their cage and are now sitting in a semi circle shape in the bottom of the hoop, but even after loads of heat and good whacks are not budging
starting to get the better of me this one
« Last Edit: September 16, 2009, 01:41:16 AM by MIKE550/4 »
Offline mystic_1
  • 1970 CB750K
« Reply #18 on: September 16, 2009, 05:35:23 AM »
Have you tried soaking the entire area with penetrating oil?  Soak, let it sit for a day, soak some more, repeat a few time.  Then heat and try removing.
Failing that, if you can find a way to freeze the parts the metal will contract making removal much easier.
mystic_1
- John Augustus Shedd
Offline MIKE550/4
« Reply #19 on: September 19, 2009, 09:08:45 AM »
well have the bearings out, heat and penetrating oil done the trick,
although is it right the rear spacer has came out out in two pieces, must stress it is not broke in two from what i can see,
can someone give me a guide on how to refit ie steps to rebuild and whether the spacer is ok to re use
thanks for a great site and i will put up some pics when i have a rolling shell
Offline IndyFour
« Reply #20 on: September 19, 2009, 09:53:40 AM »
Those are supposed to be two separate pieces as shown in your bottom pic, although, the long tube is supposed to have the little "finger guides" on both ends of it.  It looks like maybe all the pounding on the bearings drove the "finger guide" onto the smaller piece instead.  You'll need to pull it off of that part.
Really, all that the "fingers" do is help you put the axle back through by holding the spacer tube in place.  If you can manage do do that, perhaps by moving the spacer tube into position with your finger from the other side while pushing the axle through, you don't need the "fingers" part.  They really don't serve a purpose functionally on the axle other than assembly.
Did any of that make sense?  ;D
1974 CB550K
2000 VFR800FIY
__________________
Offline MIKE550/4
« Reply #21 on: September 19, 2009, 12:48:24 PM »
think so  :D
the smaller part which side does that go , is it to rear brake side
the bearings flew out just like the front and again i did not notice which way they came out
those fingers you mention, the ones that are on the smaller part are not in very good condition, can they be re used if they are not that vital then
Offline SocoMoto
« Reply #22 on: June 18, 2013, 08:21:45 PM »
i am about to replace the rear bearing and from reading all the threads, i have to drill out the stakes(which are the little dimples in each of the 4 holes) with an 1/8'' drill bit.
My questions are:
1) Am i going to damage anything if i drill too far?
2) When i put everything back together, do i have to "re-stake" the retainer(as in put 4 dimples back in the 4 holes)?
Offline Duke McDukiedook
  • Space Force 6 Star General
« Reply #23 on: June 18, 2013, 08:59:29 PM »
Just drill a little past the bottom of the stake holes.
I used medium threadlocker on my retainers.
Offline SocoMoto
« Reply #24 on: June 19, 2013, 06:35:36 AM »
Ok... so when you put everything back together, I shouldnt "re-stake", I should just use some loctite?
