Author Topic: C-Hook Engine Removal & Rotisserie Engine Stand  (Read 79056 times)
Offline blake255
  • Look Out! I'm about to crank this thing!
Re: C-Hook Engine Removal & Rotisserie Engine Stand
« Reply #25 on: January 12, 2010, 12:32:03 PM »
Make sure you check out Torchmonkey’s Garbage Rebuild over in the Project Shop.  He built a great rotisserie engine stand which you can see below.  Great work Torchmonkey!
I took a litle holiday cash and bought myself 2 engine stands from Harbor Freight and modified them to create a rotisserie engine stand a la blake255. I'll spare you the details, you can read about how it's made here:
http://forums.sohc4.net/index.php?topic=58210.0
Starting to piece the motor back together, just waiting for the gasket set. While waiting I'll be powdercoating the head and head cover.
1970 CB750 K0 Project 1
1969 CB750 Sandcast Project 2
1969 CB750 Sandcast Project 3
2009 Yamaha YZF R6
Offline 70cbk0
« Reply #26 on: January 12, 2010, 04:12:55 PM »
Thanks, I sent the pdf file and since it's easy, they're just going to use that. Told them to go ahead and make it up! get it in a couple of days. Thanks for working that up!
1970 CB 750K0
1969 CB 750K0
1966 CB77 Superhawk
1982 Honda XR200R
Offline 70cbk0
« Reply #27 on: February 13, 2010, 12:18:40 PM »
Got my C hook a bit ago, and got my engine out today. That thing worked like a dream!!!! took it out by myself, a piece of cake!!! Thanks for coming up with this idea!
1970 CB 750K0
1969 CB 750K0
1966 CB77 Superhawk
1982 Honda XR200R
Offline blake255
« Reply #28 on: February 13, 2010, 01:07:21 PM »
Awesome!  Makes me glad to know someone found it useful.
2009 Yamaha YZF R6
Offline markb
  • When I finish my current project I might be a
« Reply #29 on: March 15, 2010, 07:45:24 AM »
Here's my version of the engine hook.  I really liked the one here but didn't have the resources for cutting or welding so this worked good for me.  One advantage is the clamp collars on the top bar can be adjusted to balance the load (get the motor level).  Next time I'm going to get some loop straps made up so I don't have to mess around with the ratchet straps.
I've attached a drawing of mine if anyone is interested.  Thanks blake255 for the inspiration.
Disclaimer:  If you make one from my drawing it is up to you to determine if it will support the load you intend to lift.  If your motor drops and breaks into a million pieces, I am not responsible.  Also you need to be very meticulous when attaching the straps so that they won't slip off or cause damage to the motor.
« Last Edit: March 15, 2010, 07:51:43 AM by markb »
1969 CB750 sandcast #97 restored - Sold Restoration thread link
1969 CB750 sandcaxt #576 - Sold
1969 CB750 sandcast #1553 - Sold
1969 CB750 sandcast #1990 - Sold
1969 CB750 sandcast #5383 restored - Sold Restoration thread link
1970 CB750 K0 restored - Sold
2010 H-D Tri Glide Ultra Classic (Huh?)
Offline blake255
« Reply #30 on: March 15, 2010, 08:15:52 AM »
Thanks for posting Mark.  The round lower arm and the adjustable collars make your design a real winner.  I like it a lot.
Blake
2009 Yamaha YZF R6
Offline 70cbk0
« Reply #31 on: March 15, 2010, 01:54:31 PM »
I only had the ratchet straps as well...Bit of a pain they are...I had a ratchet strap stupidly put on the bottom to hold the 2 side straps from slipping off, and in the middle of sliding the motor out, realized  the ratchet wouldn't clear the frame. I had to remove that one and keep working the motor out. SO...for future reference, you might get away without the bottom straps, but I won't recommend it!!
OK just checked you post, Mark, looks like you didn't bother with the bottom one either. I guess if you make good and sure they can't slip, you're fine.
« Last Edit: March 15, 2010, 01:56:50 PM by 70cbk0 »
1970 CB 750K0
1969 CB 750K0
1966 CB77 Superhawk
1982 Honda XR200R
Offline markb
« Reply #32 on: March 15, 2010, 01:58:11 PM »
The top of my straps angle in a bit towards the center of the motor, so once the weight of the engine is on them they won't slip off.
Mark
« Reply #33 on: March 31, 2010, 01:54:40 PM »
Excellent, Blake!
Shall we make them and sell them to SOHC4 members?  ;D
And bike shops, and backyard operations...
Offline blake255
« Reply #34 on: April 01, 2010, 06:09:50 PM »
Thanks HondaMan!
I say let's go for it.
Blake
2009 Yamaha YZF R6
« Reply #35 on: April 04, 2010, 04:11:47 PM »
I have a fellow coming over on Tuesday, will let you know what he thinks they will cost. I've already got 2 customers!  :D
« Reply #36 on: April 04, 2010, 09:58:25 PM »
 That just  gave me a thought,, for someting even better working.. I  just got to fine tune it a bit..
Offline morethrottle
« Reply #37 on: July 01, 2010, 05:16:28 PM »
Came on here to try and find some perfect engine stand plans for painting my 500 motor......I think this is one of the best threads I've ever seen. (sorry hondaman) I like the details about mounting to a harbor freight stand. I wasn't sure about that stand 'til I read this. Excellent designs Blake255! Simple and effective!!
2005 Yamaha YZ250F (stolen)
1974 Honda CB750K4(836)
1971 Honda CB500
1971 Honda CB450
1976 Yamaha XT500C
Offline blake255
« Reply #38 on: July 01, 2010, 07:31:23 PM »
Wow, High praise for sure. (Though I still think Hondaman is in a class all his own.) Thanks for the post Morethrottle.  I hope it helps.  Good luck with your project.
2009 Yamaha YZF R6
« Reply #39 on: July 17, 2010, 06:43:00 AM »
I contacted some local shops and two of them asked for the .dxf file. Any chance I could get my dirty hands on that file? They also accept .jpg and .tif but no .pdf ?!?  Don't ask me how this technology stuff works........BTW Has anyone started production on these and can I buy one yet for about $30 ?  ;D
1971 Honda CB500
1971 Honda CB450
1976 Yamaha XT500C
Offline Muk
  • WHY OH WHY DIDN'T I TAKE THE BLUE PILL
« Reply #40 on: July 17, 2010, 07:45:17 AM »
love the sohC hook
I run a waterjet for a living ...I could cut that really easy and quick.
How much would you charge for such a thing?
Brandon
just materials enough for a couple of them 2 or 3 ...I would do it during a moment of the machine being "idle" i wouldn't mess with production time
I really just need the dimensions
that goes for any waterjetting
I would be willing to pay for one too. also if you would i have another piece that needs cut, to brackets for my drag truck. if you would be interested pm me i have been trying for a year to get someone to do it. they all say it is too small to mess with.
1976 CB550K
1978 GS750E
1980 GS550E
Offline blake255
« Reply #41 on: July 17, 2010, 03:29:58 PM »
I'm out of town at the moment, but when I get back, I'll dig up a file to send and make some calls to get quotes for a run of c-hooks.
Thanks guys,
Blake
2009 Yamaha YZF R6
Offline hotrodmetallica
« Reply #42 on: July 27, 2010, 07:52:40 PM »
Thanks for the post.  I built my "Hook" out of some 2x2x.125wall I had around the shop. Cut it out, tig welded it together, and painted it rustoleum hammer finish.
Works great.
car99r
« Reply #43 on: August 17, 2010, 12:58:53 AM »
Blake,
I was curious if you would be willing to measure the distance from end that you mounted your second stand? I do not have my engine pulled yet but would like to go ahead and get my stand ready by mounting the second stand leg on it. Appears you have it all the way to the end of the first stand but wanted to be sure.
Thanks
Offline blake255
« Reply #44 on: August 17, 2010, 06:33:05 AM »
I would be glad to take a measurement for you, but keep in mind that my stands may be a different brand than yours.  I used the Torrin Big Red stands and they are made a little differently than the harbor freight stands.  That could affect your placement.  My suggestion is to drill slotted holes in the second stand's base so that you have some adjustment.  That is the method I was going to use, but decided, since I had the time, to mount for exact fit.
Also, I've been waiting for a couple of weeks for a quote for C-hooks.  I'm not getting any response.  I'll have the .dxf file available soon.
Blake
2009 Yamaha YZF R6
Offline jaguar
« Reply #45 on: August 18, 2010, 12:27:42 PM »
i would buy one if they were for sale
Offline Harsh
  • 74 CB750 and two 72 CB350's
« Reply #46 on: November 29, 2011, 11:02:35 AM »
I know this is an old post, but has the .dxf file been posted anywhere?  If not could you send it to me?  I have searched but didn't find it.  I have a buddy that is a machinist at NASA that I am going to persuade into making me one.
Offline dragracer
  • CB750F Dragbike
« Reply #47 on: November 29, 2011, 07:31:12 PM »
Great post on a very useful tool for a one person engine removal. Also like the engine stand- makes it easier than working on a table.
Any news on if these will be for sale???? Time to pull a few SOHC engines over the winter months. I'm sure it'll work well on the KZ dragbike motors i need to freshen up as well.
Offline madmtnmotors
  • When did I get to be a
  • Sunny Central Florida
« Reply #48 on: November 30, 2011, 05:17:54 AM »
The original post (the very first post) has a downloadable pdf drawing. A dxf would not be difficult to produce, but would require access to Autocad (or similar). I have done a dwg (Autocad) of a slightly modified version with the top corner clipped at an angle, and I likely have a dwg that duplicates the original pdf since that was my starting point for the modified version. Pretty basic design, I think I had both versions drawn up in an evening. The modified version is untested and I would likely print the pattern and check the frame clearance before commiting to metal. I'll start digging around and see if I have both versions. To produce a dxf is a simple "save as" of the dwg from within Autocad. Let me know what you think. Of course any shared file carries the same disclaimer as the original poster in that:
I'm not an engineer and cannot vouch for the structural load capacity of the part. It would only be provided here as a potential solution and that the end user assumes all risk and responsibility of determining suitabilty for it's intended use.
TAMTF...
Wilbur
Projects:
Sent from my Tandy TRS-80!
Offline Harsh
« Reply #49 on: November 30, 2011, 07:53:02 AM »
Yah I downloaded the pdf, but I was hoping that since it was mentioned by the OP that he would post the file I was hoping I could just snag it.
Any work my buddy does like this is done during his lunch break so I didn't want to inundate him with converting the pdf to a workable cad file.  He (and I) would greatly appreciate it if he had a file he could just load into his machine and let it runs its course while he eats.  I don't have a cad program so I cna't help in the conversion process.
If you don't mind I would greatly appreciate any thing you can find.
