Author Topic: Oh $#!& Broke Cam Cover Bolt...  (Read 1076 times)
Offline Dave-and-his-550
  • I know the pieces fit...
« on: September 14, 2009, 04:50:01 PM »
I think I'm going to ignore it and continue with the rebuild lol...
Offline jeepurz
Re: Oh $#!& Broke Cam Cover Bolt...
« Reply #1 on: September 14, 2009, 06:29:09 PM »
welp , I did it twice! so im twice as unlucky. same dam bolt!
« Reply #2 on: September 15, 2009, 12:51:43 PM »
Can't imagine I'll have any leaking oil issues considering all the other bolts holding it down huh?
Offline jeepurz
« Reply #3 on: September 15, 2009, 07:08:30 PM »
dunno how your luck runs , but If I left it broken it would lead to catastrophic frame failure.
Offline mkramer1121
« Reply #4 on: September 15, 2009, 07:48:51 PM »
1) buy torque wrench
2)drill hole in center of bolt
3)easy out it
4)run tap thru to clean buggered threads
5)install new bolt by hand making sure not to cross thread
6) tighten to proper torque spec
:D
« Reply #5 on: September 15, 2009, 09:31:06 PM »
lol wut?
At any rate, its to late now (not really) but I already torqued everything and the engine is completely back together. I think my desire to ride the bike before winter is drastically fogging my judgment. I should probably pull it out and get another bolt in there but, like I said...(I wanna ride!)
Offline DammitDan
  • Prodigal Son
  • It lives!
« Reply #6 on: September 15, 2009, 09:39:08 PM »
Cutting corners only means you have to rebuild it sooner.  And usually with more effort due to damage which could (should) have been avoided.
I have a strong suspicion that leaving that bolt like that will result in a leaky gasket.  Sure there's "a lot of other bolts" holding it down, but each bolt has its own "area" of the gasket to torque down.  Leaving out a bolt will leave an entire area loose and asking for a leak.
I used to take shortcuts to get the bike back on the road ASAP.  Now after a lot of money spent in needlessly replaced gaskets and burned up time, I can say I don't take shortcuts anymore cause it's only gonna cause more pain down the road  ;)
Besides, is that a hole knocked in your rocker cover next to the cam chain?
« Last Edit: September 15, 2009, 09:41:08 PM by DammitDan »
CB750K4
Offline jeepurz
« Reply #7 on: September 16, 2009, 05:30:53 AM »
mine was torque'd and broke before it was on the mark, both times, I did get lucky there was a nice tit stickin out to grab ahold of.
« Reply #8 on: September 16, 2009, 11:03:57 AM »
From what I remember it is on both sides. Maybe its for the breather/bypass valve?
I did buy one of those easy-outs awhile ago just in case. I guess maybe thats a sign...
« Reply #9 on: September 16, 2009, 02:24:24 PM »
Quick update: I removed the cam cover and sure enough there was just the right length of bolt left for me to grab it with a vice grips and it easily twisted out.
1976CB550F
« Reply #10 on: September 16, 2009, 02:37:32 PM »
The earlier 500 and 550's didn't have those bolts. They really don't do anything, if you couldn't have removed it, I wouldn't have worried about it.
