Author Topic: new ignition coils  (Read 1715 times)
Offline cb(r)
new ignition coils
« on: December 05, 2005, 07:32:01 AM »
I am wanting to get new coils for my '74 550 k.  I want to get the new coils with plug wires seperate.  I need to know what the Ohms are on the original  550k.  I was thinking 2.2 ohms.  I am not sure.  can anyone help me out?
Offline SteveD CB500F
  • Ride on the Steel Breeze...
    • TVAM
Re: new ignition coils
« Reply #1 on: December 05, 2005, 07:57:54 AM »
There are loads of posts on here. Run a search on "ignition coils".
I understand (but have no proof) that the CB750/900/1100 DOHC coils use detatchable wires and can be made to fit with a little bracketry. I've also heard of VFR coils being used.
I believe your coils should be 5ohm - the 2/3 ohm coils really need electronic ignition as the extra current required toasts your points.
SOHC4 Member #2393
1971 CB500K0 (US Model)
All modern bikes now gone...
eldar
« Reply #2 on: December 05, 2005, 10:11:28 AM »
I have heard about points getting toasted, yet others say they are fine. Maybe it is the quality level of the points and condensers used. It is a common conversion though and most everyone say it is good.
Offline cb(r)
« Reply #3 on: December 05, 2005, 11:27:16 AM »
thanks basically your answer sort of planned out my next attack.  new coils, electronic ignition and bat pac eliminator.  I want to go with kick start only.  thanks
    • TVAM
« Reply #4 on: December 05, 2005, 11:28:37 AM »
As you've probably seen on here, the Dyna S seems to be the most appreciated, together with the matching low impedence coils.
Expensive though...
SOHC4 Member #2393
Offline cb(r)
« Reply #5 on: December 05, 2005, 11:58:48 AM »
ya it seems on this rebuild I wiil be spending more on coils wires and ignitiion than I have on all the mechanics combined.
Offline Gordon
  • 750K1, 550K2
« Reply #6 on: December 05, 2005, 12:15:03 PM »
and bat pac eliminator.   thanks
You might want to check out this thread before going down that road... http://www.sohc4.us/forums/index.php?topic=4412.45
eldar
« Reply #7 on: December 05, 2005, 12:25:51 PM »
Thats a rough topic there. Be prepared. Though I think a bat pac is very possible.
Offline cb(r)
« Reply #8 on: December 05, 2005, 02:28:58 PM »
wow  thanks for the warning.  well luckily I am not at the point where I want to buy this set up but none the less I think I am at least going strictly kick start.  something different for around here anyway.
