Author Topic: Tach drive Seal Removal tool..CB 750  (Read 2589 times)
« on: September 15, 2009, 10:19:11 pm »
Made one up today, worked perfect on a loose valvecover.
 Will give a better report of use on a 74 750 tommorow, looks like tank has to be moved.
 Tool consist of a drill bushing that fit in the tach drive hole , then using it as a guide you drill a 1/16 in or so hole into the seal.. at the middle point of it.
 Then you insert a screw, grab that with vise-grips, then tap it out.
 To re-intall seal, the  tool/bushing, is used to push it back in..
 works quite well by the look of it, will try to get pics taken, and a price for them in the next few days.
Re: Tach drive Seal Removal tool..CB 750
« Reply #1 on: September 16, 2009, 05:16:09 am »
 I'll buy one
Offline 1080
« Reply #2 on: September 16, 2009, 07:11:16 pm »
754 using his seal removing tool
Offline 1080
« Reply #3 on: September 16, 2009, 07:13:08 pm »
754's tach tool
Offline Raul CB750K1
« Reply #4 on: September 17, 2009, 12:14:57 am »
Why don't you simply use a socket do drive the seal in?
Offline andy8190
« Reply #5 on: September 17, 2009, 12:27:47 am »
which way does the seal go in because i am about to install mine as well. there is a side with a grove in the seal and a side without a grove, does the grove point in or point out?
figured it out
« Last Edit: September 17, 2009, 12:38:30 am by andy8190 »
Offline mystic_1
  • 1970 CB750K
« Reply #6 on: September 17, 2009, 06:12:52 am »
I know you got it figured out but the rule of thumb with seals is that the side without the groove always goes out.  If you look closely there's an inner lip with a spring in it, this side goes inwards.
mystic_1
- John Augustus Shedd
« Reply #7 on: September 17, 2009, 08:35:20 am »
"Why dont I use a socket"
 Because I have a tool made for the job.
 Because the tool probably fits tighter than a socket.
 Because the end of the tool is designed to push a seal, not beveled like a socket that will sometimes cut/deform a seal.
 The main  reason for this tool, is to get the seal out, without scarring the shaft, or the housing.
 I am still trying to find a simple handle to incorporate into the design, would make it easier to use.
 It is a bit of trouble getting the drill in place, had to remove the tach cable brace off the horn. A diegrinder style 90 deg would be perfect.
Offline mystic_1
  • 1970 CB750K
« Reply #8 on: September 17, 2009, 11:11:39 am »
For the seal driving operation, thread the top bit of the central hole so you can screw in a handle.
Maybe you can drill a hole in the side of the top flange so the same handle can be screwed into the side of the tool for holding it during the drilling operation.
mystic_1
