Author Topic: No starter safety unit or clutch switch - why?  (Read 657 times)
Offline Rddmm2
« on: December 13, 2009, 09:00:04 PM »
I have no starter safety unit or clutch switch.
The red harness plug is empty.  The y/r is hot, Blk is hot and g/r will light up on 12 v tester when I hit starter switch so it seems ready to go)
No e-start but I can kick start this way?  Can someone explain the significance of these missing parts.
(Slowly sorting out electrical issues which I posted earlier - all light circuits are now working - getting closer.)
Thanks
Offline kslrr
  • There is always a Blaster when there is a
  • Raising her up right!
Re: No starter safety unit or clutch switch - why?
« Reply #1 on: December 13, 2009, 09:10:05 PM »
Which bike?
Now  1972 CB350FX (experimental v2.0)
        1981 CB650c Custom with '79 engine (wifes)
        1981 CB650 engine
        2004 HD XL883C Custom
        1977 Yamaha XS750D (in progress)
Then 1972 CL175
        1964 Yamaha YGS-1T
No ride is a Bad ride
Offline Rddmm2
« Reply #2 on: December 13, 2009, 09:16:15 PM »
sorry...in my own little world here..
75 cb750k
« Reply #3 on: December 13, 2009, 09:36:27 PM »
The solenoid is an electromagnet.  To energize, it needs 12v on one lead and Batt NEG or GND on the other lead.
The Black lead provides power to the solenoid.  The starter safety unit has logic in it and provides the GND on the Y/R wire when the trans is in neutral or the clutch is pulled in, thereby preventing the bike from lurching forward when the starter motor is engaged.
The solenoid will not activate if 12v is applied to both the solenoid activation leads at there is no difference in potential.  It would be like connecting the bike to only one battery post and leaving the NEG terminal unconnected.  You need both a POS and NEG connection make current flow.
