If you only remember one thing I've said in this thread, remember this:The numbers for peak hp and peak torque are almost worthless. These peak numbers only give the value at
one RPM. We
do not ride at just one RPM. You need to maximize the horsepower over the most used RPM range to get the best acceleration. You maximize the horsepower over this RPM range
by maximizing the torque over this same RPM range. Hp and torque go hand in hand. At any particular RPM, the bike with the most horsepower will
also have the most torque
at that RPM. With all else equal (weight, aerodynamics, etc.) the bike with the highest
average power (weighted over the used RPMs) will have the fastest acceleration, (
and the highest
average torque over the used RPMs).
Okay... I've said in practicality we need to maximize torque to maximize power. The key is that we need to maximize these quantities over the RPMs we use the most. That is the practical part of this discussion. Now I just want us to understand enough to use the proper
language to describe what we're doing. The proper language is this:
'We need to maximize the power over the most used RPMs in order to get the best acceleration. In order to maximize the power over this RPM range, we need to maximize the torque over this same RPM range.' At this point, I'm only advocating the understanding of these words we've been using.
To understand that it's the "power" and not "torque" that is the correct
word, here is another equation.
Let's say we're doing a 1/4 mile. It takes some amount of
work to move our bike that distance.
Power is
work divided by
time:
power = work/time.
Solving this equation for the time, we get
time = work/power.
To minimize the 1/4 mile time, you must maximize the
power (over the RPMs
used, not necessarily peak hp!). And I've already mentioned how we do this in practicality.
The reason why it is more correct to say we must increase the
power is because it is the power that
defines how much work we can do in a given amount of time. It just so happens that power is made from a
combination of torque and RPM for an engine with a revolving crankshaft. Rockets, for example, increase power by increasing
thrust, and torque plays no role.
