Hello there. So I am replacing the clutch plates on my '75 CB550 and my old gasket ripped while I was removing the cover. I cannot get hold of a new gasket; I have a whole engine set on backorder and I cant find them individually.
Anyway, I decided to make one so I bought some gasket paper that was close to the original gasket thickness, traced up my clutch case cover and I cut out a gasket.
Now my question is, is there any special care that needs to be taken when installing a homemade gasket? I'd rather not use any sealers if not necessary. Also, all the posts on gaskets I have read refer to greasing the gasket, what grease should I use, motor oil? bearing grease?
TIA
