Author Topic: Cannot find same brand tire tubes for front and rear!?  (Read 11249 times)
Offline Dave-and-his-550
  • I know the pieces fit...
« on: September 21, 2009, 03:44:13 PM »
Call me picky, but I'm trying to find the same brand of tire tubes for front and rear. I've searched oldbikebarn.com, denniskirk.com, and motorcycle-superstore.com. All I want is a pair of Bridgestones, Metzelers, Kenda's, Michelins...
Looking for stock sizes for a '76 CB550:
Front: 100/90/19
Rear: 110/90/18
Could I maybe run a slightly different sized tube for the front? DennisKirk.com has a Metzeler tube that says for 110/90/19 AND 90/90/19 but its not for 100/90/19?? This is the one I'm talking about: Metzeler Tube (Click the Spec tab under the Time counter) Would this one work for the front?
I guess if it comes down to it, I could settle for different brand tubes. Maybe a Kenda and a Metezler.
Offline grumburg
  • 74550, 76400F, 72 750 67S90, 68CL90, 65 s65 66 x6
Re: Cannot find same brand tire tubes for front and rear!?
« Reply #1 on: September 21, 2009, 04:22:11 PM »
Dunlop k81s were a period correct upgrade from the 70s and are readily available. Have put 8k miles on my 75 550 and they are probably good for 5-7K more.
Fonda Honda
« Reply #2 on: September 21, 2009, 04:33:47 PM »
Cool, I'll consider them.
Whats with the different stem types? CMV, TR-4, TR-6, TR-13? Anything significant?
So whats the typical mileage you can expect from say, the Metzeler's, or Kenda's? Anybody have experience with these other brand tubes?
Offline Whaleman
« Reply #3 on: September 21, 2009, 06:27:16 PM »
WOW, I thought I was picky. Dan
« Reply #4 on: September 21, 2009, 10:12:41 PM »
There are different rubber compounds available from Metzler.  Some of the stickier tires are soft for excellent traction. other are harder for better mileage.
The road aggregate type is another factor.  Some aggregate has sharp edges for better traction.  But, they wear the tires faster.  Other aggregate uses smooth stones, which are easier on soft rubber.
It's not just the tire brand to consider, but the model of the tire within the brand.  It's always a compromise.  Soft, sticky tires usually wear faster.  Harder tires are a bit less sticky, but they wear much longer.
It's kinda like selecting the screwdriver with the correct tip for the purpose, even if the handles are the same shape and they come from the same manufacturer.
If you order the tires, you can get the proper 3.25-19 front and 4.00-18 rear from Metzler and keep the same brand front and rear.
Offline 333
  • Time for change
« Reply #5 on: September 22, 2009, 04:30:30 AM »
Of the brands you have mentioned, the Metzelers are a bit better.  They are a balanced tube, and they are a mix of natural and butyl rubbers.  Continental does this too.  I'm not sure of the Bridgestone or Michelin.  I know the Kenda is not balanced and it is all butyl.  The difference in the rubbers is that butyl will leach air over time, natural rubber won't.
CB350F0  "Scrouching Tiger"
CT70K0    "Sneezing Poodle"
www.alexandriaseaport.org
Offline Bill/BentON Racing
    • BentON Racing
« Reply #6 on: September 22, 2009, 05:45:17 AM »
Metzelers work reall well.
Lightweight and balance with little or no weight
Last one said .5 gram. Bill
BentON Racing Website
BentON Racing Facebook
masonryman
« Reply #7 on: September 22, 2009, 05:35:56 PM »
I just put these on my bike this summer, I'm happy with them, bought them at the local Honda dealer little pricey for a vintage looking tire. I think I had about 220 in the set, mounting them myself
« Reply #8 on: September 22, 2009, 07:55:42 PM »
Hmmm. Kenda is the brand my local shop uses...$16.95 each. They leak over time huh? Well thats no good, who the hell wants that?! I guess I'll order my own tubes as well.
eastbloc
« Reply #9 on: September 22, 2009, 08:15:29 PM »
I've never had a tire that didn't leak over time.  Whether it's through the rubber or through the valve, somewhere, somehow, air will escape, and you'll need to check your tire pressure and inflate it from time to time.
Offline MJL
  • Don't listen to me, I'm no
« Reply #11 on: September 23, 2009, 09:50:17 AM »
Psst, this is an inner tube thread...
« Reply #12 on: September 23, 2009, 11:42:00 AM »
Here...I got same brand tubes from Dennis Kirk in stock sizes for my 500 that fit your exact dimensions.
http://www.denniskirk.com/jsp/product_catalog/Product.jsp;jsessionid=50XXWCIUUWNPFLA0WTVSM4VMDK0NCIV0?store=&skuId=54143&mmy=
http://www.denniskirk.com/jsp/product_catalog/Product.jsp?skuId=&store=&catId=&productId=p54141&leafCatId=&mmyId=
thnx for looking. IRC huh? Those are probably cheaper (In quality) then those Kendas my local store stocked. I'm taking Stan's (333) word for it, BUTYL rubber will leach air quicker then a natural rubber compound. Going by his word on this one though, I have no experience obviously  :D
Offline MJL
« Reply #13 on: September 23, 2009, 12:26:00 PM »
I believe you have it backward. Car tires are made with a butyl inner liner as it holds air better than the rubber of the tire.
Offline Bill Vaughan
« Reply #14 on: September 23, 2009, 08:49:55 PM »
Another same-brand option:
Front - Continental RB2 (3.25 x 19) Stock #T290150
Rear - Continental K112 (4.00 x 18) Stock #T290157
Both available through Tires Unlimited   http://www.tiresunlimited.com/ALL%20TIRES/Continental/continental_conti_twins.htm
1972 Z50A
1973 ST90
1975 CL360
1971 CB450
1975 CB550
1978 FLH
2003 FLSTS
2006 FLHRSI
Offline Gordon
  • 750K1, 550K2
« Reply #15 on: September 23, 2009, 09:11:33 PM »
Tubes, guys, TUBES.  Not tires.
« Reply #16 on: September 25, 2009, 08:53:30 PM »
Haha,Gordon is spot on. I'm looking for same brand tubes FOR my tires! Mainly so I can know the quality, and life expectancy of them both and replace if necessary when the time arises, when it will.
Offline HavocTurbo
  • Angry little bastard of an
  • Can you tell?
« Reply #17 on: September 26, 2009, 12:41:42 PM »
Usually if buying for stock size tires you can match tubes with the rims. But if you've changed the size of your tires it's good to match to the tire itself.
So what size rims and what size tires you running?
I carry michelin, irc, and house brand tubes.... I'll do my best to hook you up.
'48 HD Panhead - Exxon Valdez
'78 CB550K - Fokker CB.3
'78 Honda CB750K - Mavrik
09 XL883L - No Name
« Reply #18 on: September 26, 2009, 08:35:07 PM »
Cool Havoc, I'm running stock rims with stock tire sizes:
110/90/18
100/90/19
I'd prefer Michelin's over IRC, curious what else ya got also.
Offline HavocTurbo
  • Can you tell?
« Reply #19 on: September 27, 2009, 01:46:08 AM »
Okie dokie here's the big ones...
Start with the rear.
110-90-18 (3.75-4.25) Commonly sized.
Michelin
4.00-4.60 / 18 - TR6 Valve - $20
IRC
3.50-4.00 / 18 - TR4 Valve - $13
House Brand
3.50-4.00 / 18 - TR4 Valve - $18
Kings
3.50-4.00 / 18 - TR4 Valve - $12
On to the front...
100/90/19 (3.25-3.50) Commonly sized.
Michelin
3.25 / 19 - TR6 Valve - $17
100-110/90 / 19 - TR4 Valve - $25
(HeavyDuty Version) - $30
IRC
3.25-4.10 / 19 - TR4 Valve - $13
100/90 / 19 - TR4 Valve - $20
House Brand
100-110/90 / 19 - TR4 Valve - $18
Kings
3.25-3.50 / 19 - TR4 Valve - $12
Shipping would be about $5 to the lower 48.
Ok so here's a shot of the valves for you. Just so you know what the differences are.
Want my $0.02?.... Sure you do. :D
Downside to tubes is you get what you pay for. Michelin's have a lot of tech for tubes. Double folded joints and what not. Plus a better mix of rubbers and polys.
If you don't want the price.... my house brand is the best I've found so far. I use them in dirt and adventure bikes and have yet to have spontaneous catastrophic failure. Minus the occasional nail or sharp rock.
Anything else would be a cheap fix to get you "home".
Hope this helps.
09 XL883L - No Name
masonryman
« Reply #20 on: September 27, 2009, 06:16:59 AM »
I'm speachless, When bought tires the last time I just said;
 " gemme some tubes for those also"
I don't even know what brand they are.  :-[
Mark
Offline Gordon
  • 750K1, 550K2
« Reply #21 on: September 27, 2009, 08:43:38 AM »
Mark
Same here.  The only time I ever had a tube fail in my 8 years of riding on tubed tires was when I ran over a nail, and I wouldn't expect any brand of tube to hold up to that. ;)
Offline HavocTurbo
  • Can you tell?
« Reply #22 on: September 27, 2009, 07:59:36 PM »
Dive your bike really deep into the corner and slam on the brakes to avoid a dog.... tubes like to fail about there.  ;D
09 XL883L - No Name
Offline Gordon
  • 750K1, 550K2
« Reply #23 on: September 27, 2009, 08:05:37 PM »
No thanks! ;D ;D
masonryman
« Reply #24 on: September 27, 2009, 08:06:38 PM »
weight back, throttle up, screw the dog. If i'm going down because of a dog I'm takin it with me
