Author Topic: 750K0 Carb assembly question  (Read 1146 times)
Offline zoo mob
« on: September 24, 2009, 11:53:51 PM »
Took my carbs apart quite a bit ago, and am finally getting around to putting them back together, but I have this feeling I'm missing a part; is there a t-joint fuel passage between carbs 2 and 3 or just the two between 1 and two, and 3 and four? Thanks.
Andrew
 1970 750 K0
 1980 BMW R100T
 1980 GS1100E
 1993 XR650L
Always looking for more
Offline fishhead
  • Why don't you go.....Well, you know the rest.....
Re: 750K0 Carb assembly question
« Reply #1 on: September 25, 2009, 05:01:18 AM »
Theres a fuel Tee between 1 and 2 and 3 and 4. The center has nothing on the Sancast carbs.
Quote from:  Vanna White
Photobucket slide show (Fishhead Big Brakes)
http://s111.photobucket.com/albums/n130/dgfischer/Fishhead%20Big%20BRakes/?albumview=slideshow
Offline Johnie
« Reply #2 on: September 25, 2009, 05:19:47 AM »
Looks correct to me. Just be sure you mounted them back in the order they were taken off. Putting carbs 2 & 3 on the outside would not work as far as the fuel delivery goes.
1970 CB750K0 - Candy Ruby Red
1976 GL1000 Sulphur Yellow
Oshkosh, WI  USA
