Author Topic: CB200T  (Read 1749 times)
Jaredl2055
CB200T
« on: September 24, 2009, 06:12:39 PM »
I have a Honda CB200T and when i fire it up it revvs very high like around 6K and i cant figure it out.....any ideas would be a big help
thanks in advance
Jared
Offline bucky katt
  • i am a pastafarian!
    • facebook
Re: CB200T
« Reply #1 on: September 24, 2009, 06:15:25 PM »
are the carbs synched? sounds like you have an air leak in the carb-to-engine boots.
Mark Twain - Notebook, 1894
Offline Green550F
  • Nothing is as cool as that which you made.
Re: CB200T
« Reply #2 on: September 25, 2009, 06:02:34 AM »
try spraying carb cleaner around the boots. if the idle changes it's a leak.
also check the choke...
93 Kawasaki Voyager XII
70 Honda CL350 Cafe
Offline Tretnine
  • Prove it,
  • Figuring it out, one expletive at a time.
    • http://www.behindbarsmotorcycle.com/
Re: CB200T
« Reply #3 on: September 25, 2009, 06:37:01 AM »
agreed, choke could be stuck on. Check all throttle cables, also. Depending on the condition of the bike they could be totally rusted, broken, whatever or just stuck. If your choke is stuck on you'd have this issue.
2009 Kawasaki Concours, 1978 cb550k, 2006 BMW F650GS
Member of the AMA
Offline tbpmusic
Re: CB200T
« Reply #4 on: September 25, 2009, 07:00:22 AM »
CB200's are one of those bikes that the throttle cable has to be routed exactly right on, no leeway at all.
If you need photos, let me know.
I've experienced your problem - everything looks/acts fine, then you put the tank on and it instantly redlines when you start it up, yeah??
Also, when you bolt the carbs to the head, you have to do it very evenly, one side of the carb to the other.
There's a rubber o-ring on the manifold that deforms if you don't do it evenly, allowing big-time air leaks.
Don't ask how I know all this..............been there, done it.
Bill Lane
Offline Halvin
  • Life is 10% what happens to me & 90% how I react.
Re: CB200T
« Reply #5 on: December 03, 2009, 06:10:44 AM »
I have just acquired a 74 CB200 and am having the problem you allude to in your post concerning the throttle cable.  can you provide more information about the correct routing of the cable?
Hal
Offline tbpmusic
Re: CB200T
« Reply #6 on: December 06, 2009, 01:05:36 PM »
Route the throttle cable along the right side of the frame, under the right tank mount rubber thing.
The "splitter" on the cable will fit right under the coils - then route the left carb section between the two upper engine mounts. It will be just barely long enough, but it's the only way it will work.
Then when you put the tank on, be really careful you don't move the cable any, or that left carb will not allow it's slide to go down all the way.
I always wait to put the air cleaners on until the tank is in place, so I can actually see that the slide isn't hanging up........
Bill Lane
Offline Halvin
Re: CB200T
« Reply #7 on: December 06, 2009, 05:23:27 PM »
Thanks for the help.  When I acquired the bike it had a '75 CB360 gas tank on it.  Since no alterations had been made the tank kind of floated between the legs when riding.  I am bidding on e-bay for the correct tank and I'll apply your routing method when I install it.
Another question:  The cable operated disc brake doesn't seem to have much stopping power.  The disc looks smooth and even.  Is this to be expected from this setup?
Hal
Hal
Offline tbpmusic
Re: CB200T
« Reply #8 on: December 06, 2009, 05:53:31 PM »
Hal
After I rebuilt mine, it works fine.
Not as good as a hydraulic disk, but definitely better than a drum brake.
Bill Lane
