Author Topic: cb350...do any other fork caps fit?  (Read 5876 times)
Offline johnspeck
« on: September 26, 2009, 05:38:47 AM »
the search function hasn't turned anything up...and i haven't seen much on ebay.
besides the expensive preload billet fork caps i've seen on one website,
are there any other bikes that interchange?
Offline johnspeck
Re: cb350...do any other fork caps fit?
« Reply #1 on: September 26, 2009, 06:00:44 AM »
the OEM part # for my bike is:
honda front fork bolt 90123-317-700
Offline kslrr
  • There is always a Blaster when there is a
  • Raising her up right!
« Reply #2 on: September 26, 2009, 10:40:25 AM »
Do you have any motorcycle salvage yards near you?  I wouldn't be suprised if the forks on CB350/360 twins and any of the other smaller CB's.
Now  1972 CB350FX (experimental v2.0)
        1981 CB650c Custom with '79 engine (wifes)
        1981 CB650 engine
        2004 HD XL883C Custom
        1977 Yamaha XS750D (in progress)
Then 1972 CL175
        1964 Yamaha YGS-1T
No ride is a Bad ride
dumbcity
« Reply #3 on: October 01, 2009, 04:13:46 PM »
i've been looking around for a few days myself and haven't found anything. not even the expensive ones you mentioned...
Offline tbpmusic
« Reply #4 on: October 01, 2009, 04:44:20 PM »
CB/CL 350 K2/K3 and CL450 K3/K4 used the same part
"If you can't fix it with a hammer, then it's an electrical problem"
Bill Lane
 '71 CB450 Mutant/ '75 CB200/ '81 CM200/ '71 C70M
Offline chickenman_26
    • Motorcycle Consumer News
« Reply #5 on: October 04, 2009, 08:39:19 AM »
Bill, I put his part number into the Zedder crossover program, and I got this.
Part # = 90123-317-700
Part Description = BOLT, FRONT FORK
Model Count = 6
CB350F 1972 350 350 Four Street
CB350F1 1974 350 350 Four Street
CB350G 1973 350 Super Sport 350 Street
CB350-K4 1972 350 Super Sport 350 Street
CL350-K4 1972 350 Scrambler 350 Dual Sport
CL350-K5 1973 350 Scrambler 350 Dual Sport
MCN DTF
« Reply #6 on: October 04, 2009, 08:41:48 AM »
Bill, I put his part number into the Zedder crossover program, and I got this. These are the forks with the damper cartridges inside. The top of the damper rod screws into the fork cap.
Model Count = 6
MCN DTF
Offline tbpmusic
« Reply #7 on: October 04, 2009, 11:20:26 AM »
That list looks good for the part number you listed.
You never said what K-model you had, so I was looking at an earlier number.......
Bill Lane
Offline Alan F.
« Reply #8 on: October 04, 2009, 12:20:04 PM »
Some other hondas (from Hahonda's list of axle sizes, steering bearings, and fork tube sizes) that also used 33mm forks, maybe some of them use the same or compatible caps:
33 Honda CR-80R (84)
33 Honda CR-80R (85-86)
33 Honda TLR-200 (86-87) "Reflex"
33 Honda XL-200R (83-84)
33 Honda CMX-250C (85-87, 96-04)
33 Honda CMX-250C2 (99-00)
33 Honda TL-250K "Trials 250" (75-76)
33 Honda CB-350F/F1/G (72-74)
33 Honda CL-350 "Scrambler 350" (72-73)
33 Honda CB-360/T (75-76), CL-360K (74), CJ-360T (76-77)
33 Honda CJ-360T (76-77)
33 Honda CB-400A "Hondamatic" (78
33 Honda CB-400T I & T II "Hawk" (78-79)
33 Honda CB-400T (80 From 2004662 - 81)
33 Honda CB-400T (80 To 2004661)
33 Honda CM-400A "Hondamatic" (79-81)
33 Honda CM-400T (79-81)
33 Honda CM-400E (80-81)
33 Honda CM-400T (79-80 To 2114344)
33 Honda CB-450SC (82-86)
33 Honda CM-450A/E (82-83)
33 Honda CX-500 (78-79), CX-500C (79), CX-500D (79)
33 Honda CX-500C "Custom" (80)
Offline tbpmusic
« Reply #9 on: October 04, 2009, 06:05:20 PM »
If it's any help, I found that CX500 caps (before air forks) fit my CB400T forks perfectly, and are still available for about $6 each..........
Not saying they'll work for you, but it's worth a try.
I still have the rusty old CB400T caps - I could send you one to try, if you want.........
Bill Lane
Offline johnspeck
« Reply #10 on: October 05, 2009, 05:58:00 AM »
thanks for all the info!
my bike is a '72 cb350k4.
here's a link to the billet preload types:
http://www.400fourstore.com/Merchant2/merchant.mvc?Screen=PROD&Store_Code=4&Product_Code=1957&Category_Code=C
of course, these are for the 400f, but i've seen these used on stock 350 forks.
tbpmusic: if you wanted to send a cap, that'd be great!  i can pm you my info, and of course i'll cover shipping.
Offline tbpmusic
« Reply #11 on: October 05, 2009, 09:01:09 AM »
John -
Let me rummage in the shop - I rarely throw anything away, so it's probably in there somewhere.
Just a matter of what box it's in - I'll get back to you, ok?????
At $6 each (the early CX500 caps), it was a great discovery for me......
Bill Lane
Offline tbpmusic
« Reply #12 on: October 06, 2009, 07:30:07 PM »
Well John, it looks like I did throw the fork caps away, because I sure can't find them anywhere.
Sorry.
But at $6 each, it's not a budget buster to order the CX500 caps and try them.
Remember, pre-air forks CX500...........
Bill Lane
Offline johnspeck
« Reply #13 on: October 07, 2009, 05:29:05 AM »
i appreciate it!
i'll definitely look into those caps...i'm going through and slowly replacing all the worn parts and various hardware on my bike; by spring it should be almost completely refurbed.
« Reply #14 on: October 09, 2009, 06:43:09 AM »
i appreciate it!
Your forks have damper cartridges in them, and the top of the damper rod screws into the bottom of the fork cap. I posted above all the models that have compatible caps. No other caps will work. I had a spare pair here that were a bit rusty on the chrome, and I unfortunately tossed them out. I can get you a pair from my local yard if you can't find anything. But they won't be pretty.
MCN DTF
Offline johnspeck
« Reply #15 on: October 11, 2009, 09:55:19 AM »
i appreciate it!
thanks for posting...the ones i have are functional, but rusty.  i've seen a few sets of NOS ones go on ebay for big bucks.  i was hoping there might be a part still available that will work.
Offline Dos
  • Owner of a cb350f
« Reply #16 on: May 09, 2016, 09:40:59 PM »
Does anyone know the ratchet size for this bolt? I gotta change my fork oil and I don't want to use a vice grip to remove them.
When you put the oil in you just pour it straight in right? no specific way?
Offline Dos
  • Owner of a cb350f
« Reply #17 on: May 11, 2016, 09:23:54 AM »
Sorry socket size *
Offline kslrr
« Reply #18 on: May 20, 2016, 08:20:32 PM »
Looks like it's 22mm.  I don't have a 22mm, but the 23mm was a little loose.
        1981 CB650 engine
Then 1972 CL175
        1964 Yamaha YGS-1T
