Topic has been discused ad neausea.
Isn't the stock rim only 1.85 inches wide? Modern wide tires simply don't fit on such a narrow rim properly.
If you dig some, the manufacturers will specify the rim width required for the tires they have designed. Dealers aren't smart enough to figure this out. And, they would rather sell you the most expensive tire you will buy, as the that gives them the highest profit margin. Bigger tires make more profit.
For a 1.85 rim, a 120 metric is too wide, giving excessive center wear because you have to over-inflate the tire in order to make the sidewall rigid.
As the tire "squares off", you have to fight the bars in turns to hold your line.
Works great new, as it wears out (enevenly) the bike becomes more of a pig.
The stock rims were designed for tires made well before the industry added metric sizes or tubeless into their product lines.
But, if you like ketchup in your coffee....
