Author Topic: Here you go Sam  (Read 3233 times)
Offline sparty
  • I just play one on TV
  • My engine is 100% stock... wink.
    • Gallery
Here you go Sam
« on: September 28, 2009, 06:23:40 PM »
Upon Sam's request I am posting my build page to this part of the forum.
http://home.comcast.net/~aentz626/site/
Keep in mind that this page is still under construction.
Art (Sparty)
1972 CB750 K2 Cafe' Style
GO AWAY SNOW AND COLD!  Can you see the Hot Rod wants to run...
“That's thirty minutes away. I'll be there in ten.”
  • Moderator
Re: Here you go Sam
« Reply #1 on: September 28, 2009, 06:33:48 PM »
Well done Art 8) 8) 8) 8) 8) can you post your dyno results ? ;)
Sam. ;)
Offline sparty
    • Gallery
Re: Here you go Sam
« Reply #2 on: September 28, 2009, 06:37:30 PM »
Sam. ;)
Sam, I have been looking for my dyno results on my home computer but they are no where to be found.  I had to turn in my old work laptop and I am afraid that they were saved on that computer.  I may have saved them to my external hard drive, which is where I will check tomorrow.  If it isn't there I am SOL.  I also lost a bunch of build photos, but Mike is working on finding them on his computer.  The ones I took are lost forever, which makes my tear up thinking about it.
Art
  • Moderator
Re: Here you go Sam
« Reply #3 on: September 28, 2009, 06:41:24 PM »
They are on this board somewhere, but where is anyones guess,  :( :( :( :(that was the reason for starting this section.
Sam. ;)
Offline sparty
    • Gallery
Re: Here you go Sam
« Reply #4 on: September 28, 2009, 06:48:45 PM »
Sam. ;)
Found it Sam.
http://forums.sohc4.net/index.php?topic=38205.0
Re: Here you go Sam
« Reply #5 on: September 28, 2009, 06:51:10 PM »
My son is working on it Art but he is a high school senior with a job, girlfriend, SAT's, MCAS tests, college applications etc. Me....I'm busy as hell to. I know I have them it is just a matter of locating them.
Offline sparty
    • Gallery
Re: Here you go Sam
« Reply #6 on: September 28, 2009, 06:52:30 PM »
No hurry Mike.  When you send that CD I would also like some of those 1/2 step CR needle shims.  I'll pay you wnat ever you need.
Re: Here you go Sam
« Reply #7 on: September 28, 2009, 06:53:04 PM »
I took some photos as well - if you need them let me know...although I think I only got the finished product...
cheers
Andy
Offline sparty
    • Gallery
Re: Here you go Sam
« Reply #8 on: September 28, 2009, 06:56:53 PM »
Mike,
I was wondering if the work you did might have pushed my compression higher than the 10.5 the pistons make because it does make some wicked HP.  The decking of the head might have something to do with it.  Since I can't kick it over I was thinking that the compression is higher than 10.5.
« Last Edit: September 28, 2009, 06:59:02 PM by sparty »
Offline moham
  • .fnord.
Re: Here you go Sam
« Reply #9 on: September 28, 2009, 08:16:12 PM »
There are three pages worth on the member gallery side (which I'm sure you probably knew...)
http://gallery.sohc4.net/main.php?g2_itemId=3622
78 750K-The Ocho
74 550-The Cherry Picker
70 750K0 motor-Dick in a Box
