Where are you at in your case splitting,tell us what you've done so far. You should have fun!,Bill
I'm stuck...don't want to beat on the case too much to get it to open.
Have all the case bolts out, but I'm not sure if the clutch needs to
be removed before splitting the case?
It looks like the case is sealed together with some kind of glue or gasket sealer?
Also, my pistons are shot and the camshaft appears to be somewhat worn...any
ideas on where to get OEM parts or aftermarket (preferably on the U.S.)?
thanks
