Author Topic: I've been K0'd!  (Read 151465 times)
Re: I've been K0'd. wiring updates, engine work, PO lied, stock bore.
« Reply #75 on: May 08, 2012, 07:51:51 AM »
It's funny, it didn't even cross my mind to find new stock cables. I guess that says something about my thought process. Always trying to make something better, sometimes takes you the long way. When you are done is it really better? I really like the feel of this cable nice and flexible.
I think the ground is NLA, that's why i went Yamiya for big $$. Can't remember if the Pos is NLA or not.
« Reply #76 on: May 08, 2012, 08:56:49 AM »
Ron,
Are the Yamiya K or F cables?
« Reply #77 on: May 08, 2012, 09:14:45 AM »
Ron,
They only do K parts, so unless its a crossover part number, it'd be a K. Their parts listing says K0 to K5.
But the more I think about it, i got those from Motogrid. The Pos cable is available, and the ground cable had a substitute part number that crosses with a Goldwing. When i got it the eye is obnoxiously large, but the length was OK. Think I wish I had bought the Yamiya part, the eye looks more like the original. But for twice the price.
Or, get one from Don R
But back to your question: Looking at a motogrid fish for a 75F, they both carry 392 center digits (not the 300) meaning they are somehow different and likely though not for sure, not crossable, and the 392s are NLA.
« Last Edit: May 08, 2012, 09:27:04 AM by MCRider »
« Reply #78 on: May 08, 2012, 10:53:12 AM »
This one (K0) had a braided cable in a rubber cover, the ground was also braided. too bad they are wo nasty.  I have my F out in the shop, I'll compare them after my guitar lesson this afternoon.
 I have a crashed F parted out too, I'll check that wiring for cables. I think the ground I used for a pattern was an F. it's a shame I can't match the ends perfectly,
« Last Edit: May 08, 2012, 10:56:27 AM by Don R »
« Reply #79 on: May 08, 2012, 11:12:11 AM »
The diff between a 300 and a 392 could just be a small amount of length. But there is some real difference or Honda would have just kept the 300 part number.
« Reply #80 on: May 08, 2012, 07:45:33 PM »
The positive cable that I suspect came from the F is very short. The solenoid was removed from the battery box so I'm not positive it's the one.
« Reply #81 on: May 14, 2012, 08:40:29 PM »
Just goes to show ya, can't believe anything a PO says. That sucks. So are you gonna bore it and throw in an eBay 836 kit?
« Reply #82 on: May 24, 2012, 07:25:53 PM »
Yes I am. I have the kit already. I  ported a head for it a while back but kept thinking of the stuck junk looking K0 engine in the corner. It would be a correct head for the bike and they may be a bit better in the ports and chambers. The rocker shafts rotate too. I started taking it apart and noticed aluminum retainers, then triple springs then another 812 kit. The cam had been switched to a later stock one and most of the threads need helicoils. then I peered into the intake port and Viola! it's ported too! The Honda gods were bound to shine on it sooner or later.
 EDIT, it is not a correct head for 14,100 it has the added center bolt. It was original porting on a K0 head. I hadn't seen that before. I still haven't unstuck that K0 engine.
« Last Edit: November 21, 2016, 08:29:43 AM by Don R »
Re: I've been K0'd. wiring updates, engine work, big bore kit!
« Reply #83 on: May 25, 2012, 07:00:07 PM »
I plan to buy an eBay 836 kit as well. Will be following...
« Reply #84 on: May 25, 2012, 10:05:52 PM »
The local machine shops can't do the 65 mm bore, the hole starts too small. The bar doesn't fit. I'm avoiding the old fashioned bottom up boring bars. One said he could put cutters in his hone and do 10 or 20 thou. but not 4mm.
 I keep getting referred to a guy I went to high school with. He can do it in his garage. He bought a small machine when the local yammy shop closed. I'm checking with him next. i'll need to be impressed when I talk to him. He's the cyl head guy too.
« Reply #85 on: May 25, 2012, 10:10:50 PM »
Triple spring and aluminum retainer. I think my brother wants this one back. I found one retainer with the keepers nearly pulled through.
« Last Edit: October 01, 2025, 06:44:38 PM by Don R »
« Reply #86 on: May 25, 2012, 11:03:12 PM »
Don, is that aluminum or titanium?!
Offline Greggo
  • Somebody's
  • Helmets Save Lives. Period.
« Reply #87 on: May 26, 2012, 06:49:55 AM »
Wow, very nice.  I've never seen triple springs in a SOHC4!
Offline lucky
Re: I've been K0'd
« Reply #88 on: May 26, 2012, 11:28:34 AM »
This is the frame repair kit I got from I bikes it is only tacked in place. It will be finish welded this winter when the bike is apart. The tubes and braces were completely gone and the new center was cut from a wrecked 75f.
the before pic
I love those carbs!! Easy to work on and remove the slides.
Then Honda ruined them.
BTW....You have the carbs numbered backwards in the photo,
#1 should be on the left.
« Reply #89 on: May 29, 2012, 04:09:08 PM »
:') Good catch, a friend imposed that number system on me when the slides were put in reversed, then numbered Lol, that took a while to figure out! I now know they will fit backwards but work terribly.
They are possibly Ti, not sure how to tell the difference.
« Reply #90 on: May 29, 2012, 04:12:16 PM »
I got my 3.5 mm female ends today, should be able to make some proper cables now.
« Reply #91 on: May 29, 2012, 07:20:00 PM »
I would think aluminum would scratch easily, more so than Ti. I have my Ti buttoned up or I'd test them. PM guru Rieck. Most of the aluminum I've seen (pictures only) are anodized. 3 springs is overkill IMO but they'll close up without floating! May take away too much HP though??
Spark test: [url][http://en.wikipedia.org/wiki/Spark_testing/url]
« Reply #92 on: June 06, 2012, 10:24:44 PM »
My part time dragster driver is a pro Stock fabricator and works with titanium all the time I'll have him check them out when it's apart. doesn't matter anyway, my brother wants to use that head on his engine now that I took it apart and knocked the dirt off of it.
 I have my old K4 head ported and the chambers modified anyway. I found a deal on some new stock valves, would have liked to increase the intake valve size but it's just a street cruizer anyway. I'm expecting a call about the machine work. The guides feel tight to me but I'll defer to they guy doing my machine work.
« Reply #93 on: June 13, 2012, 08:45:15 AM »
The cylinder is off to be bored, an old high school buddy. He's been working on bikes since I've known him. I trusted him with a very nice cylinder hope it comes out OK. His price seemed a bit high at $200 but he's local so no shipping or long drives required.
« Reply #94 on: June 13, 2012, 08:54:18 AM »
Gotta dig out alot of metal to get to 836. Several passes each hole. Some will overtax their bar to save time. Better to take it slow, smaller bites. Takes time. time = $$
« Reply #95 on: June 21, 2012, 12:38:09 PM »
I may regret it but I told him to take his time. I'd rather wait than have him hurry through it. He usually charges $60 a hole so I got the buddy price.
 In the meantime I body worked  some dents from a dyno cover and shifter cover. The existing ones had peeling chrome on them.  The work left very tiny cracks on the bottom where I worked the dents out. I JB welded the inside and called it a day. Looks good on the bike. It is a some expense spared project.
« Reply #96 on: July 23, 2012, 08:21:03 PM »
Hoowaah, I have cylinders! He apologized for taking so long it was a pretty big cut and he took his time.  The piston clearance is .0012,  top ring end gap is .012, second ring .010 and the oil ring is .0025. I've only checked one cyl so far. I ordered heavy studs and nuts tonight. I have some cleaning to do, and more checking.
I replaced the front wheel bearings. The front end is back on except somehow the unicorn triple tree was cracked, it broke the rest of the way but I have another one that's not powder coated. Yes, I had the D washers in it some old PO  might not have. The powder coat sucked into the break so it was cracked before.
« Last Edit: July 23, 2012, 08:23:48 PM by Don R »
« Reply #97 on: July 24, 2012, 08:42:38 PM »
It cooled off a little today so I ventured into the shop and removed the cylinder studs. I wrote a little about it in the tips and tricks section. Pistons and ring fitting continues tomorrow.
Offline Greggo
  • Somebody's
« Reply #98 on: July 25, 2012, 10:47:53 AM »
Keep up the good work Don!
« Reply #99 on: July 25, 2012, 10:50:19 AM »
Ditto! Fellow Dead Head.
