Author Topic: electricl problem  (Read 779 times)
Offline neil10
electricl problem
« on: December 05, 2009, 03:00:04 AM »
Cb 750 k4
Bike just stopped no  power anywhere
check fuses ok  wiggled a few things then weird stuff happens lights come on when they shouldn't  finally bike starts
Offline Gordon
  • 750K1, 550K2
Re: electricl problem
« Reply #1 on: December 05, 2009, 06:09:30 AM »
Check the plug on the back of the ignition switch.
Offline leekellerking
« Reply #2 on: December 05, 2009, 01:36:30 PM »
Also, check the wires around the fusible link (on the starter switch if the same as my CB650SC).
While you can start and run without the charging system, you can't do crap if the circuit throught the fusible link is cut.
Lee
Cb 750 k4
My Nighthawk is put together with wire and zip ties, burns oil, and handles like a pig.  I love it!
Offline gane
  • Gane
« Reply #3 on: December 05, 2009, 01:46:22 PM »
2 Quick tips. 1st, glass fuse holders tend to corrode and/or lose tension w/age. 2nd, wire harness  where it exits frame under tank (at front) and runs to H/l access hole sees more motion(wear) than any where else. other frequent suspects are main switch contacts and handlebar swithches.. Luck g
Offline 750goes
  • it will live
« Reply #4 on: December 05, 2009, 01:50:58 PM »
If you still have the original 3 fuse panel under the left sidecover - check the back of the panel for corrosion - also for loose fittings - I just replaced mine - it had a similar problem of inconsistent power, and a bit of a wriggle and all was well - until the next big bump...
« Reply #5 on: December 05, 2009, 04:12:37 PM »
Clean battery cables.----------- I know, but try it anyway
Offline 1974blaze
« Reply #6 on: December 06, 2009, 10:06:55 AM »
i agree with all. especially the corrosion check at battery and fuse box.  i just had this happen and after cleaning and re-soldering fuse box she's all better.  as a side note, simply loose battery cables on my acura messed with all kinds of things including starting and blowing bulbs.
Offline bucky katt
  • i am a pastafarian!
    • facebook
« Reply #7 on: December 06, 2009, 10:57:04 AM »
check the fuses with a multimeter, they should not show any resistance. a fuse can LOOK like it's ok and still be blown
Mark Twain - Notebook, 1894
