Author Topic: cb 750 k4 bronze bush  (Read 2080 times)
Offline neil10
« on: October 04, 2009, 03:14:55 AM »
need specs to make my own
Offline babyfood1217
  • The only way to drink espresso is as a
  • I miss my baby...
Re: cb 750 k4 bronze bush
« Reply #1 on: October 04, 2009, 06:59:26 PM »
Pretty sure NO ONE has any idea what you are asking for.  I'm assuming swingarm, so are you asking for material type (yes, I can read the word "bronze" but there are several types of machinable bronze)  or dimension (in which case the best bet might be scour the board.  Still need to do this on mine, so I can't help you here.
I need help moving my project bike from Wisconsin to Seattle, WA.  Willing to pay well.  Contact if interested.
SOHC member: #438
Project: 1976 CB750K
GSXR forks, Monoshock Rear end, 836 in progress, RC51 pipes, custom frame and everything else.
« Reply #2 on: October 04, 2009, 09:05:19 PM »
Pull yours apart, MEASURE IT & do it right..
« Reply #3 on: October 04, 2009, 11:33:47 PM »
What if his is worn out? ::)
Offline lordmoonpie
    • Moonpie
« Reply #4 on: October 05, 2009, 04:36:43 AM »
Pull mine apart, measure it and...on no that won't work - I only just got it all back together! :D
1994 Ducati 888 SP5
1951 Ducati 50cc Cucciolo
1981 Yamaha XV750 SE
« Reply #5 on: October 05, 2009, 05:04:58 AM »
Come on LM, do the right thing and pull that sucker apart, you know it's for a good cause!  ;D
« Reply #6 on: October 05, 2009, 07:51:32 AM »
It should be worn..
 so pull out the sleeve and turn it true, then fit the bushings to that.. then 10 years later you can bore/ream the same bushing out to fit a new sleeve... use it up..
 you are not measuring the worn bushing, you will be measuring the max/min size if the components..= better fit..
Offline neil10
« Reply #7 on: October 05, 2009, 09:04:46 PM »
Any idea what is a good clearnce between shaft and bush
