Author Topic: A series of questions  (Read 929 times)
Offline timdhawk
  • 1978 CB750K
« on: October 04, 2009, 10:54:36 AM »
- I just realized that when i took my rear hub apart (78 cb750) there was no distance collar in it. Is this a must have or just a nice to have?
- since apart, do i need to/should i replace the piston rings on the lower seats of the forks?
- can the threads on the rear final drive flange (the peice the sprocket bolts to) be re-tapped? the ones the retainer screws into.
- can anyone tell me where this o-ring goes? is it around the hub or inside the peice in front of it? (not the bearing, the other one)
« Last Edit: October 04, 2009, 11:15:02 AM by timdhawk »
In deeper than I should be...
Re: rear hub distance collar - needed?????
« Reply #1 on: October 04, 2009, 11:13:34 AM »
if you mean 1 of the 2 that live in the rear hub?.. YES they are NEEDED..
Offline turboguzzi
« Reply #2 on: October 04, 2009, 11:14:09 AM »
a must have, otherwise you'll ruin the wheel bearings in no time.
have you taken the bearings out and seen there's none? hard to believe that you been running without one.
TG
Offline timdhawk
  • 1978 CB750K
Re: A series of questions
« Reply #3 on: October 04, 2009, 11:27:23 AM »
sorry, figured I'd better ask all my questions rather than 5 separate posts.
this one here was not in the hub when i took it apart. I didn't even know i was supposed to have it until i startewd looking at parts drawings for ordering.
« Reply #4 on: October 04, 2009, 02:39:41 PM »
The O-ring goes on the shoulder of the bub, and is held in with the chrome collar.. do believe it keeps grease in the drive.
Offline Bill/BentON Racing
    • BentON Racing
« Reply #5 on: October 04, 2009, 05:07:30 PM »
754 right, o ring goes on hub,chrome collar goes over it, DO NOT put together w/out missing part,no way it can work correctly!Bill
BentON Racing Website
BentON Racing Facebook
Offline turboguzzi
« Reply #6 on: October 05, 2009, 02:17:32 AM »
whoever omitted that spacer when redoing the bearings has to be sent to jail. it could end in big tears. good that you spotted it.
TG
