- I just realized that when i took my rear hub apart (78 cb750) there was no distance collar in it. Is this a must have or just a nice to have?
- since apart, do i need to/should i replace the piston rings on the lower seats of the forks?
- can the threads on the rear final drive flange (the peice the sprocket bolts to) be re-tapped? the ones the retainer screws into.
- can anyone tell me where this o-ring goes? is it around the hub or inside the peice in front of it? (not the bearing, the other one)
