Author Topic: from spain cb 650 chopper  (Read 15662 times)
Offline pacochopper
« on: October 06, 2009, 06:00:04 AM »
Hello to all, my nick is pacochopper
Sorry my english is very very very bad.
I write from Sevilla, España.
I am constructing a bike, cb 650:
-frame: yamaha xj 650 very modified.
-swingarm: chopped 11 cm.
-gas tank: sportster.
-front end: sportster.
-head light: bates 3".
-seat: metalflake gay jajaja.
-bar: yamaha sr 125.
-suspension: sportster low.
-front wheel: yamaha virago.
The engine this one very good condition, but I have serious problem electrical.
The bike, she has been stopped 8 years, the engine has only 30000 km.
Once with everything mounted in the chassis, cleaned carburators, new battery....press start button and runnnn. The engine sound very well. But after a minute in march , the fuse of the solenoid breaks and one of the cdi (oki mps-200) burns, the silicona is melted and throws(adds) white smoke.
I buy two cdi to good price.
Since the electrical installation is the original one of the motorcycle, I think that it(she) can be damaged, make simplified.
I install the new cdi to her, press start button and ruunnnn again. But after 1 minute, the engine stops , the fuse of the solenoid returns to be broken, I replace it, and again one of the cdi this one burned. I believe that I am going to cry.
Has this happened to someone?
For that it happens?
I wait for solutions
Thank you very much and excuse my language
Un saludo a todos
« Last Edit: October 06, 2009, 06:19:53 AM by pacochopper »
Offline moham
  • .fnord.
Re: from spain cb 650 chopper
« Reply #1 on: October 06, 2009, 09:21:43 AM »
Very cool. I dig it...much gusto y bienvenido al Forum SOHC...
78 750K-The Ocho
74 550-The Cherry Picker
70 750K0 motor-Dick in a Box
Offline mystic_1
  • 1970 CB750K
« Reply #2 on: October 06, 2009, 09:27:13 AM »
Sorry I do not know much about the CDI ignitions but I would certainly check all of the existing wiring for short circuits.
The bike looks very cool!
mystic_1
- John Augustus Shedd
Offline pacochopper
« Reply #3 on: October 07, 2009, 06:22:22 AM »
Thanks
The coils not screwed to the chassis, not ground to the frame. Only the wiring of the cdi.
If there is no ground of the chassis in the coils. Is it possible to burn the cdi?
Las bobinas (coil) estan sueltas, no estan fijadas al chasis. Solo tiene conectados los cables que van al cdi. Supongo que hay demasiado consumo y al cerrar el circuito por el cdi lo quema ¿no?. ¿Que pensais?
Gracias
Offline moham
  • .fnord.
« Reply #4 on: October 07, 2009, 09:34:39 AM »
Paco, yo espero que puedo ayudar, pero no se mucho de los electricos. Y no hablo mucho espanol tambien, pero hay mucha gente aqui que saben mucha de todo Los motorcycles...buena suerte.
moham.
78 750K-The Ocho
Offline bucky katt
  • i am a pastafarian!
    • facebook
« Reply #5 on: October 07, 2009, 09:58:46 AM »
i LOVE that seat! the shape and the color, dont suppose you know what brand it is?
Mark Twain - Notebook, 1894
Offline pacochopper
« Reply #6 on: October 07, 2009, 01:32:03 PM »
Hello
The seat this one in the catalogue of W&W cycles
http://www.wwag.com/cgi-bin/WebObjects/WebSite
Waiting for help with cdi burned
Offline Frankenkit
  • Industrial Strength
« Reply #7 on: October 07, 2009, 01:50:46 PM »
Paco,
Assuming you mean the ignitors
two of these: for the CDI...
Part of the problem might be the grounding for your coils.  Do you have the coils mounted under the tank, bolted directly to the frame?  On the left side, there is a small green wire that also bolts beneath the coil.  Is that still attached?  Try taking those bolts out and just cleaning and polishing the mating surfaces, to make sure the ground is as clean and tight as possible, then reconnect.
This problem might be a bit over my head, though.
2012 CBR250R "Black Betty"
1980 CB650c- (sold) Delilah
1973 CL350- Lola?
Stuff for sale
Offline pacochopper
« Reply #8 on: October 07, 2009, 03:53:40 PM »
Hola Kit
These are the spark unit burned:
oki-mps 200
The coils without ground, they were fixed by tape for the test on the road.
Can it be the problem?
Sorry for my language an Thanks
Offline pacochopper
« Reply #9 on: October 07, 2009, 04:30:03 PM »
Searching the Internet there are more people with the same problem:
 79 CB750K CDI spark units/idling problem/Crash bars
Hey,
I posted this on the maintenance forum, but I figured I would give it a try over here too.
I just ordered off eBay a working set of CDI ignition spark units for a CB750K.
Last week my Dad took the bike for a ride and came back and the bike was smoking under the seat. He shut the key off, I had some water that I poured on the spark unit to put the flame out, and the spark unit was basically fried. I noticed that one of the battery cables was lose, but it never hit the frame. Also, my units are the ones that have the tar on the back of them, so that is actually what was burning.
I was speaking to the gentleman I bought the spark units off of, and he said those units require a solid 12 volts to them. He said I should check the resistance to the ignition coils before hooking up the spark units and trying to get the bike running again.
How should I check the coils?
Is there anything specific I should test with a voltmeter?
If so...what leads should I connect the meter up to?
Once I get the bike running, I am going to hook a voltmeter up to the battery to make sure I am getting a good 12 volts charge, the alternator may be giving up too.
Second question, on a cold start up the bike is kind of cold blooded, but if you hold the throttle for about 3 minutes at 2000-3000 rpm, I can let go and the idle will rest and run at 1000 rpm which is where it is spose to be. If you ride the bike for about 5 minutes up and down the road, the bike will then idle around 3000 rpm and absolutely will not come down. If you reach under the tank and pull on the throtlle cable it idles, but as soon as you let go it goes right back to 3000 rpm. I put a good oil on the upper part of the cables figuring maybe it was just getting stuck, but it still isn't working right.
What else could cause this before I spend $150 for a mechanic to look at it?
Third and final question...What crash bars fit a 79 Honda CB750K?
This motorcycle thing is all new to me so I need all the help I can get. Cars I am fine with, bikes I have alot to learn.
Thanks!
-Dave
Question
Ive got a 1982 honda cb750f supersport.  The bike has about 30,000 miles on it. I was riding  down the road the other day when my main fuse blew.  I looked for a possible problem, and when I didnt find one, I stuck a piece of wire where the fuse goes so I could get home. After I started my bike I smelled something burning.  One of the spark units had melted, but the other was fine.  I disconnected the burnt unit and drove home.  when i got home, i removed the burnt wire from the harness that goes fron the spark unit to the coils and to the run switch.  The wire was black with a white stripe and it was the only wire that had melted.  I ran new wire, replaced both spark units and replaced the run switch.  The bike ran fine for about 3 days then it melted one of the new spark units.  Ive searched for a shorted wire, but i didnt find any.  What could be causing this problem?  Thanks for your help
Waiting for help
Thanks
Offline Frankenkit
« Reply #10 on: October 07, 2009, 05:51:58 PM »
Now, I'm not a custom bike builder, but I seriously think you need to have a good, solid ground for the coils. I suspect that could be much of your problem.
1973 CL350- Lola?
Stuff for sale
arttbags
« Reply #11 on: October 08, 2009, 05:29:36 AM »
i like it..
Offline pacochopper
« Reply #12 on: October 08, 2009, 02:37:20 PM »
Thanks
I really think the problem is the ground in the coils
Gracias Kit
Offline Frankenkit
« Reply #13 on: October 08, 2009, 02:44:48 PM »
De nada.  Espero que resuelva su problema.
1973 CL350- Lola?
Stuff for sale
Offline pacochopper
« Reply #14 on: February 24, 2010, 01:17:28 AM »
Hello again
the project progresses
There is a new problem:
The bike starts very well, has good idle at low rpm is fine, but fails high. The bike does not accelerate, from a quarter turn throttle command fails. It comes down makes a noise like "wooooooooooooohohhhhhh" jejeje sorry. On the road does not exceed 100 km / h, if you try to go faster fails.
What I have to use jets for open admissions?
What steps I use to adjust the valves?
Can you think of anything that might cause this problem?
Regards, pardon by my English and thank you very much again.
Offline Frankenkit
« Reply #15 on: February 24, 2010, 01:36:19 AM »
I've never seen a 650 run reliably with pods, but that's my own small contribution.
1973 CL350- Lola?
Stuff for sale
Offline pacochopper
« Reply #16 on: February 24, 2010, 02:41:22 PM »
Thanks kit
A pleasure to greet you again
rayray2316
« Reply #17 on: March 06, 2010, 12:41:52 PM »
Hey bro, I would have to agree with kit. I have an 80 cb650c im doing and the pod thing did notwork well, but what did you do with your shock set up to get it so low? Im still debating if I want shocks or struts.
Offline HIELOROJO
« Reply #18 on: March 06, 2010, 01:01:37 PM »
Hola Paco, buena maquina, pasate por www.sohcspain.com y date de alta y pon alli tu duda. Un saludo.
Offline pacochopper
« Reply #19 on: March 18, 2010, 07:47:27 AM »
hi
It solved my problem. I needed some main jets even larger. Using the method of trial and error I found her just right, I've put about 140 and I have limited somewhat the air inlet. It rolls like a shot. It goes very revolution, she will put a bigger sprocket to change the relationship.
Rayray2316 the bike is so low because the chassis is custom made for me. Not if the chassis so you can download the original. The rear shocks are of low sportster 2004.
I am now doing the exhaust. It's very pretty, then put photos.
Sorry for my English
A greeting
Offline pacochopper
« Reply #20 on: March 15, 2011, 04:21:06 PM »
long ago solved the problem of burning cdi.
grounds and a controller giving a little more than recommended voltage ....
The bike has already walked a good bunch of miles.
runs every day.
Two weeks ago there was a custom living in Seville and the organization asked us to participate.
Uploaded with ImageShack.us
URL=http://img291.imageshack.us/i/img1150lq.jpg/][/URL]
Offline scunny
  • don't call me expert
« Reply #21 on: March 15, 2011, 07:25:31 PM »
hey paco, nice looking bike.
present-CB 650 retro
            VTR1000F3
           XL250S riverbed rocket
           TS250[sold]
           TS185[sold]
           XL125S[sold]
           MT50 (white)
           MT50 (red)[sold]
           KN250/XS400 project
           SL100[sold]
           XL250R
           pedal(pub bike) leaks oil
Offline CycleRanger
  • No comment about being an
« Reply #22 on: March 15, 2011, 07:57:54 PM »
Well done!
