Ahh-OK,
The CBR has the "wheel" type of adjuster, but you can't always go by the lever as the Buell master and this CBR master cylinder, the levers are very different, but interchange, as they also do with many other master cylinders.
The CBR master cylinder comes in 1/2(12.7mm), 5/8, and 14mm and look identical to each other so you have to be carefull to get the correct one that would work with your set up.
The CBR master has more rounded corners on the reservoir.
