Author Topic: Vacumn guages for Carb synch  (Read 560 times)
« on: October 08, 2009, 07:08:51 PM »
Going to look at a set for sale,
 Any good for setting carbs?
 Pros? Cons?
 Worth having?.. not worth it ?
Offline Patrick
Re: Vacumn guages for Carb synch
« Reply #1 on: October 08, 2009, 08:09:44 PM »
I use vacuum gauges to sync carbs. The only issue is making sure they are all calibrated equally. This is easy to do. Just attach the gauges to a carb one at a time and see if they are reading the same. You will need inline dampers or they bounce too much to read. I use little in-line valves that I picked up at Home Depot.
I also have a mercury gauge, but my engines like to slurp up mercury and spew it across the environment, producing really stupid coyotes around here.
Patrick
1970 CB750 K0
1982 VF750S Sabre
1987 VT1100 Shadow
1979 Yamaha XS11
1969 Yamaha DT1B
etc.
Offline the technological J
  • deliciouso!
« Reply #2 on: October 08, 2009, 08:15:31 PM »
definatley worth if i have a mercury manometer and it works great but theres a heated thread about ones with some other liquid and it not working as well.... theres also homemade ones if u do a search... but the gauges are not as acurate but  unless ur racing or in to ultra high performance u  should be ok with them...... i got my manometer for 40 on ebay
94 ST1100..Gone
72 750 K2 Stay tuned!
