Author Topic: 650 cams with a decked 550 head  (Read 485 times)
Offline jays75
« on: October 09, 2009, 12:57:07 PM »
Simple question for you all.  Since it's possible to use a 650 cam in a 550 is it possible to deck the 550 head.  If so by how much?  There may be clearance issues if I'm not mistaken.  I figure if I take the 550 head to the shop for clean-up why not get a little taken off the bottom.  If you all advise against it then it's probably for good reason.  Thanks for any advise.
