Author Topic: 400f master cylinder questions...  (Read 1039 times)
Offline zoo mob
« on: October 11, 2009, 11:53:57 AM »
Well, this is my first m/c rebuild; the bike came with all of the disassembly done as far as I can tell, the hole at the end seems empty. Can I just put this stuff together and be good to go? Sorry to be so vague, it seems like it will be too easy and I'm missing something.
Andrew
 1970 750 K0
 1980 BMW R100T
 1980 GS1100E
 1993 XR650L
Always looking for more
Offline zoo mob
Re: 400f master cylinder questions...
« Reply #1 on: October 11, 2009, 07:30:51 PM »
Anyone?
Andrew
 1970 750 K0
 1980 BMW R100T
 1980 GS1100E
 1993 XR650L
Offline raisin75
« Reply #2 on: October 11, 2009, 07:47:26 PM »
As well as it's good and clean, put the parts in and do a bench bleed to help get the flow of fluid started. Just put a little fluid in once the MC is back on the bike and put your finger over the hole before you put the banjo bolt on. Pump the lever and you should build pressure against your finger and get fluid around your finger. USE A TOWEL AND DON'T LET ANY FLUID GET ON ANYTHING!
Dee
Nesbit, MS
1983 GL650i (daily rider)
1977 CB750A
1972 Suzuki TC90
