Author Topic: Massive Oil Dump out!? Why did this happen?  (Read 1090 times)
Offline superstarpunani
« on: October 15, 2009, 01:19:25 PM »
So I have just finished with my 1975 CB550 K1 complete rebuild. The bike went down to the frame and the motor was down to the complete (not split) cases and all the way back up. The bike is now amazing. So I was preparing for a first small scoot around town just to start putting a few miles on the bike, bit by bit to let all the parts match up. Oiled up the bike and off i go, maybe 2 miles away the oil light comes on and I pull over to the side and pushed it back to the shop. Took of the sprocket cover and drive chain sprocket and it looked like the seal the drive shaft comes out with was allowing all of the oil to come out. But it is a new Honda Part seal. So i replaced it again, and looked at the oil pump. The oil pump had not been taken apart, since the bike only had 24,000 on it, so I then took off the pan and cleaned out the pickup, checked the releif valve in the pump, re-oiled and tried again. There has not been any other problem since then, about 15 miles later. But why was the oil pushed out of the seal to begin with? Is that what happens with the releif valve releases and or did the oil pump prime wrong? Any answers would be appreciated.
Travis
Offline Hush
Re: Massive Oil Dump out!? Why did this happen?
« Reply #1 on: October 15, 2009, 01:23:53 PM »
Sounds like that new seal wasn't quite fitted right, sometimes when they are just not right in they will "pop" out under pressure when the engine is running.
Hopefully the bike runs well for you now. :)
Offline JohnG
  • 1976 CB750F - original owner
« Reply #2 on: October 15, 2009, 08:55:03 PM »
Get an oil pressure gauge so you always know what is going on.  Won't cost you $10 and might save your motor sometime.
1971 CB450
1979 CB750F
1982 CB900F
1983 CB1123F - Rick Stetson motor
Offline noexit
« Reply #3 on: October 16, 2009, 12:05:19 PM »
Did you have a breather plugged? This happened on my CL350 once. The center stand pinched off my breather, and when pressure built up in the case, my shifter shaft seal popped out.
