It's buttoned up and dry. I had a hell of a time getting the carbs to stop leaking. I think a couple of the overflow pipes are cracked so I put a piece of thin tubing on them. It runs but seems a bit noisy. On this one I just did a hone and new rings, lapped the valves in, valve guide seals, new chains and tensioners, gaskets and o-rings, everything else looks good. The tappets are bit noisy but as a friend of mine says -"a loose tappet is a happy tappet".
Next - save for the candy blue green paint job and pipes. I suppose I could steal a set of pipes off one of the K1's in the meantime. While the saving is going on I could play with the C95 and see if it actually runs.
Cliff.
