A step forward and a step backward. Assembled all the parts in the upper and lower cases, smeared Hondabond on the machined surfaces (the Hondabond is runny but the tube is about 5+ years old), mated the them, installed all the bolts, installed the shifter assembly and.........................it won't shift. The shifter fork must be jammed. Take it all apart, but leave the shifter assembly on the lower case and sure enough the shifter fork is stuck. The cases did mate cleanly though. Get that fixed but now I have to remove the dried on Hondabond which means taking everything out of the cases to be sure there's no bits of the bond staying/hiding in the cases. And I think I should get some new bond. The jammed fork may have saved me from grief later as the Hondabond seems to have dried hard and not semi dry as the tube says.
My buddy "Do It Again Cliff" has come back. The cases did look good bolted together though.
Cliff.
