Author Topic: CB 550 charging problems  (Read 1303 times)
Offline firefighter_zach
« on: October 19, 2009, 09:29:14 AM »
Hey guys,
I have a 74 cb 550 that is not charging. I dont know much of anything about electronics but i think i want to get a solid state reg/rectifier. Where can I get one and what advantages does it have? I've got DYNA coils with Hondaman resistor pack that will be put on eventually, and want to update to electronic ignition in the future. Don't know if that will help or not. Right now I have stock coils on the bike and still no charging.
1974 CB550K-in pieces
Offline edbikerii
    • Gallery
Re: CB 550 charging problems
« Reply #1 on: October 19, 2009, 06:27:13 PM »
Which Dyna coils do you have?  3 ohm or 5 ohm?  You need 5 ohm on a CB550.  3 ohm coils require more power than a CB550 charging system can generate.  Been there, done that.  If you just got 'em, then call Dyna and maybe they'll swap you the right coils (they did for me about 15 years ago).
Don't bother with solid state reg/rect unless you have diagnosed that your existing reg or rect are indeed bad.  I went that route, and the solid state unit made no difference whatsoever.  The mechanical reg is adjustable, and amazingly reliable.
Hey guys,
SOHC4 #289
1977 CB550K - SOLD
1997 YAMAHA XJ600S - SOLD
1986 GL1200I - SOLD
2004 BMW R1150R
« Reply #2 on: October 19, 2009, 06:31:54 PM »
Must have a multimeter for diagnosis.
Or, just keep changing parts 'til is works. $$$
