Author Topic: Brake Fluid  (Read 2595 times)
Offline Gary Puckett
Brake Fluid
« on: October 19, 2009, 05:41:31 PM »
Honda car dealers claim that only Honda brake fluid should be used in Honda cars. I have a full bottle left over from having Honda cars. Is it appropriate to use for a classic Honda C B 750? It is Dot 3. Is this just a gimmick to sell Honda brake fluid?
« Last Edit: October 19, 2009, 06:24:54 PM by Gary Puckett »
1974 CB750
1974 CL200
1982 XR200
2004 TRX350
Offline Steve F
Re: Break Fluid
« Reply #1 on: October 19, 2009, 05:46:31 PM »
DOT3 brAKe fluid is all the same stuff as far as I'm concerned.  Just don't keep brAKe fluid around too long in opened (as in broken-seal containers) for more than a few months as the stuff absorbs moisture.
Offline Steve F
Re: Break Fluid
« Reply #2 on: October 19, 2009, 05:53:44 PM »
So Gary, is this you?  How's the band been doin' lately?  ;D
Re: Break Fluid
« Reply #3 on: October 19, 2009, 05:56:18 PM »
I'm not sure it is possible to break a fluid.  Perhaps if you freeze it first....  Of, course it is no longer a fluid then, is it?
Re: Break Fluid
« Reply #4 on: October 19, 2009, 06:16:25 PM »
I guess you earned your stars for sarcasm?
1974 CB750
1974 CL200
1982 XR200
2004 TRX350
Re: Break Fluid
« Reply #5 on: October 19, 2009, 06:24:20 PM »
No, I had sarcasm well before any stars.
I also had English spelling and grammar lessons.
Have schools changed that much since the 50s?
Offline mick7504
Re: Break Fluid
« Reply #6 on: October 19, 2009, 06:44:18 PM »
Yep agree.
Dot 3 is Dot 3.
Dot 4 is Dot 4 which supposedly doesn't absorb moisture as readily as Dot 3.
Even Toyota today reccomend using Dot 3 in their systems.
I have heard that using Dot 4 in their systems can cause major havoc.
It appears to be a bone of contention like the engine oil discussion - But we're not going there!! ;D ;D
Dot 3 is the devil we know and I think it is the safest bet providing the container has been well sealed.
If I was you
I'd be worried about me.
Re: Break Fluid
« Reply #7 on: October 19, 2009, 06:51:03 PM »
Yep agree.
Dot 3 is Dot 3.
Interesting,i have ALWAYS used dot 4 brake fluid and never had a problem.
Just went out and checked and its definitely dot4....
Offline mick7504
Re: Break Fluid
« Reply #8 on: October 19, 2009, 07:09:25 PM »
Yep agree.
Dot 3 is Dot 3.
I've done the same myself without any problems too.
I did hear that not using Dot 3 in the late model Toyota Landcruiser systems can be an expensive mistake.
It is hard to know what is right and what isn't and what to believe.
I guess by putting in what the manufacturer reccomends at least covers your backside.
If I was you
Re: Brake Fluid
« Reply #9 on: October 19, 2009, 07:12:51 PM »
I think most of the confusion can be attributed to Auto manufacturers wanting customers to use their own products, i am not too sure about the cruisers though, next time i see my mechanic i will ask and see what he says..
Re: Brake Fluid
« Reply #10 on: October 19, 2009, 07:26:33 PM »
Look Steve, he's in woodstock too!  Sorry, Gary I'm a smartass too. D.
Offline mick7504
Re: Brake Fluid
« Reply #11 on: October 19, 2009, 08:22:02 PM »
Pre Woodstock  ;D
If I was you
Offline 1974CB750rider
  • 1974 CB750K4 46000 miles
Re: Brake Fluid
« Reply #12 on: October 19, 2009, 08:28:41 PM »
I've heard that if you have a brand new brake system on our old bikes, and when I say new I mean everything. New lines that have never been used, new or fresh built and clean master cylinder and caliper you can use dot 4 but have been told not to mix dot 4 and dot 3. As far as brake fluid goes Dot 3 is Dot 3 I don't care if it comes from the dealer or from the local parts store.
People with closed minds cannot learn new things.
Re: Brake Fluid
« Reply #13 on: October 19, 2009, 10:52:13 PM »
Oh boy, here we go again PLUS the crowd is in another of it's moods  8)
TT uses spell check ha ha  ;) We don't need no education according to Pink Floyd.
Just for all this I'll mention DOT5 and leave it at that.
No one usually means any harm here. We actually mean to prevent harm.
Offline BeSeeingYou
Re: Brake Fluid
« Reply #14 on: October 19, 2009, 11:10:47 PM »
I used a can labeled synthetic Dot3&4 when I rebuilt my break ;D system.  Why, because it was sitting on my shelf unopened.  So far so good.  Are two Dots better than one? ;D
« Last Edit: October 19, 2009, 11:48:19 PM by srust58 »
Offline mick7504
Re: Brake Fluid
« Reply #15 on: October 19, 2009, 11:23:59 PM »
Please mister please - not the Dot 5.
We didn't mean it - Promise we'll all be good boys now  :o  :o
Did someone mention Dot 5.1???????
"We Gotta Get Outa This Place"  ;D  ;D
If I was you
Offline w1sa
Re: Brake Fluid
« Reply #16 on: October 19, 2009, 11:40:49 PM »
They've all been superceded by Dyna Dot X.............and it guarantees not to brake your stopping system................. ;D
Offline mick7504
Re: Brake Fluid
« Reply #17 on: October 19, 2009, 11:56:34 PM »
If I was you
Offline Steve F
Re: Brake Fluid
« Reply #18 on: October 20, 2009, 03:53:11 AM »
By mixing them you now have DOT3.5
Offline Inigo Montoya
Re: Brake Fluid
« Reply #19 on: October 20, 2009, 06:10:21 AM »
Hmm mick's article does not mention synthetics. I use a synthetic dot4. Has worked very well. Regardless, a person should drain and refill their fluid every other year if not every third year. Just my thoughts.
Re: Brake Fluid
« Reply #20 on: October 20, 2009, 05:03:14 PM »
Ahhhh but does it stop your braking system..... ;D
Re: Brake Fluid
« Reply #21 on: October 20, 2009, 05:15:15 PM »
Have you heard about the new brake fluid thats coming out at the first of the year. Its called DYNA 6.  ;D ;D ;D ;D ;D ;D ;D
