Bill, the Kawi should make lunch meat out of the Honda - just built for different ends of the spectrum.
Isn't the CBX near 100 horses and the GPZ at something near 130 and 100 lbs lighter? It's been a long time.
Gordon
Hey Gordon. Yeah they ARE two DIFFERENT sorts all right. Both will run pretty good, but you are right as far as the Kawasaki running the wheels off of the CBX.
The GPZ speedometer is topped at 160mph.
Not that I'LL ever see anywhere near THAT speed. The CBX speedometer tops at 85 and there' no doubt that it will run way past that. Of course I can't check ANY speed over 85 because it will bend the needle of the speedometer and those things are way too costly to mess with. Now, IF I could find a 79' speedometer for a decent price, I'd see about getting one, so IF I wanted to kick it up a bit (past 85), I could. Both bikes pull VERY strong! I'm sure that at a point, the GPZ would walk off from the CBX. But, that "big 6" sure sounds FANTASTIC! Riding the CBX, handling wise, isn't much different from many others. It doesn't seem so big, to me, when I ride it. The GPZ has a whole different feel to it and, in turn, seems to beg to be put through the paces! I'd have to double check the specs on the two. I've seen them, but don't recall the specifics.
